How do you get paint off concrete?
Jason B
PA
I have some white paint on my driveway that I can't get off. Is there something I can use to get it off wthout staining the concrete?
Will S.
The First State
Goof-Off is supposed to remove dried paint. Scrape off what you can with a sharp-edge scraper; then Goof-Off, followed by a pressure washer.
J
Jason B
PA
See pic. I'm assuming it was some type of white spray paint??? Still use goof off?
djjsr
In the cornfields
If you remove it, how will the helicopter know where to land?
If that's spray paint, there's "graffiti remover" in a spray can that works pretty good (keep it away from your car).
J
Jason B
PA
I want to put the H, the other way. Hmm, graffiti remover, maybe home depo has it. I tried some other stuff on it that was super strong, and nothing changed.,
icefisherman
mn
If its a latex paint I would use denatured alcohol (try that first), If its spray paint its probaly a lacquer based so you could try lacquer thinner. Try just a liitle bit at first, if it doesnt stain dump it on there and use a wire brush and scrubb. If that dont work try m.e.k and if that dont work I dont know if anything will work.
What did you try that was super strong?
P.S. The thinners will probally remove any sealer on your driveway if thats a concern.
icefisherman
mn
Kind of funny when you dont want the paint to stick to concrete it will, but when you want it to, like a garage floor, people have issues with it comming up without any solevents.
Interex
Dallas, TX
3400+ PSI pressure washer should do the trick nicely. Go ahead and wash the entire area to ensure you don't have a washed H left.
J
Jason B
PA
What I tried the frist time was "wash thinner", that my neighbor have me.
BioHazard
I agree. If you get a strong enough pressure washer you can carve off the top layer of concrete. You don't need one that strong, but a good pressure washer should have no problem with a little paint. A hot water one would work even better.
