How do you guys miter a replacement board when the board isn't square?
TT_Vert
Wauconda, IL.
I had a piece of siding at the corner of my house that goes up the roof. The front edge was mitered. Given that there are no 90 degree angles on this I cannot just throw it in my miter saw and cut the miter. How does one go about something like this? As quick and very inaccurate workaround I used my bench mounted bandsaw and approximated 45 degrees but it's not the best or more accurate way to do this. Quick 3D renderingUntitled.jpg
BillK
Beautiful Southern Maryland
Wont your miter saw cut oddball angles ??? Usually if I have something really off the wall I will take a sacrificial board and sneak up on the angle. Cut a little and try it... repeat until you find the correct angle. Then cut the real thing.
T
TT_Vert
Wauconda, IL.
It will but that angle needs to be 45 degrees. When you set the board onto the saw it's not a parallel to the 45 degree angle I need to cut if that makes sense.
T
TT_Vert
Wauconda, IL.
Maybe this will help. W/ a compound miter saw how do you figure out the angle to cut the miter so the other angles still parallel the surface it sits on? My question is how would I cut this given the face i need the 45 on is NOT 90 degrees to the piece sitting on the miter saw table.
T
TT_Vert
Wauconda, IL.
compound miter saw. takes a bit to figure out how to place the wood. try doing crown molding and you get the idea.
sometimes you have to cut the compliment on a scrap piece to use as a mount for the good piece.
years ago i did do crown molding, probably wasted as many pieces as I used. So the principle is about the same then? I didn't have to use a compound miter saw when I did my crown molding though.
Dave
Bert_
NW Iowa
I'm getting nothing out of those computer drawings. A picture of the real thing or that part of the house would be a lot more useful
LeonardY
Southern California
I would scribe a line and use a block plane. It's faster than you would think.
I'm assuming this is on a house. Are you planing to caulk the joint?
A few pictures of the actual piece and where it going would be really helpful.
T
TT_Vert
Wauconda, IL.
here is a pic. The triangular piece is what i replaced and would have loved to know how I could use my miter saw to make that miter rather than using my band saw to sand it to a guestimated 45 degrees I didn't do a perfect job sadly and i didn't have it perfectly flat so where the miter mostly lined up the piece was not parallel to the roof line. I had to raise the back of the piece up a hair to parallel the roof line and it in turned messed up the bottom of my miter gap so I had to caulk it.. The long edges are straight the shingles make it look like they aren't though.
Larryjones
WV
Cut that angle before you cut the others. But, generally, sand paper, caulk and paint make me the trimmer I ain't.
FMB4
Dave
Did the same long ago (crown and base). I cut the longest sections 1st and still managed to waste more than I expected. And this was using a simple miter box. Meanwhile, the posts above should get squared away (sorry, couldn't resist).
dfiler2
NW Minnesota
You could attach the piece to a light piece of plywood that had a 90 degree corner, then cut your 45. It could be screwed through the back to keep it from moving.
glennm
can’t you cut the 45 on a table saw with the blade tilted to 45. That would need to be your first cut. Or, router with a 45 degree bit
