How do you store your bungee cords?
Strouty
Southern Maine
Right now mine are tossed in a milk crate, if I want one, I get ten because they are all hooked together. Anyone have a better idea?
tjdux
Southern Nebraska
You could make a rack out of pipe that has 2 parellel pipes running along that you clip one end of each cord too. Wrap the longer ones around a few times. The problem is that it will use a large amount of wall space.
nh_yota
Seacoast New Hampshire
Group them by size and bundle them up. I find that most of the time I'm only using the same couple of bungees in the back of my truck, and the rest sit bundled up into I need to use them a few times a year.
lakeroadster
Central Colorado
I hang them on the back end of the garage door overhead rails... but then again you likely have a gazillion of them. :spit:
I have half a gazillion ratchet straps. I have a steel vertical locker... like the one's we had in high school... it's ideal for hanging the ratchet part at the top of the locker on the coat hooks, and then rolling up the straps and sitting them underneath the ratchets.
Strouty
Southern Maine
I could do a pegboard deal with the sizes all on one peg, that would minimize wall space. I know someone on here has an elegant solution.
fordnut85
My trucker buddy uses a couple different lengths of PVC pipe long enough to you can hook them on the top and bottom. Keeps them nice a neat on the truck.
Sent from my Pixel using Tapatalk
nes999
IL
Cut in half, thrown in the trash.
I have seen too many people lose teeth when one lets loose.
There is nothing a bungee can do that I cant do with a ratchet strap.
Sent from my VS988 using Tapatalk
txvwnut
Bedford, Texas
I tend to hang mine kind of where ever, some are hanging off the press and some are hanging on a conduit beside my tool box. I used to put them in a centralized place but found having them in a few different locations makes it quick and easy to grab one when needed.
Warrenator
Newberg, OR
Wadded up in a big ball with the ratchet straps in the back seat of the pickup. Make sure all the hooks are grabbing at least two straps so the ball stays intact when you pull it out and cannot be untangled without 5 minutes of swearing, preferably in the rain while parked in front of a store blocking the entrance.
kylefitz
Kansas City, mo
4" diameter pvc pipe slightly longer the your longest size. Cut openings in the side space slightly longer then the smaller sizes.
Rewind97
Mississippi
I like this idea. I didn't know how many I had till I gathered them all up from various places, I bet I have 50 of those rubber ones the truckers use!!!
For the ratchet straps I roll it up and twist a wire around it then toss it in an ammo can.
I keep 4 ratchet straps in the truck and for those I bought a small bag with a pull string to close it. Yea If I only need one they all come out, but it's not too bad to deal with.
WhiffySpark
I have 2 lengths of 1x3? Fasten to my wall. Every thing hangs off of those. I have one length below it where I hang my longer chains from the top one and they go behind the bottom one to keep them tidy
shelteredV
The Rock
I fall into the milk crate gig. Certain curse words ensue when I need to get a bungee out. Whats worse is right next to that crate is the ratchet strap crate. Yup, it ain't much better thanks to my guys tossing them back in all rat flucked.
Dave in Mass
Massachusetts
I got lucky that the prior owner left one wall of a chain link fence (4 Ft) jutting out from the wall next to my work bench. It used to be a dog run in the garage. It is perfect for bungees as the holes are big for putting the hooks in, and you can use it for any length bungee up to 6ft.
Leaflessshadetree
Don't ask.
I don't even waste time by cutting them. (Actually I don't even pick them up).
Most of the ideas here work for tarp straps as well.
2oolhound
BC Canada
I have extruded metal mesh with a big enough diamond pattern to allow the hook to go straight through, then hook them with slight tension on the other end. When I need one they are always there and you can just grab the appropriate length needed.
Flatheadpopup
C/S Colorado
This is similar to how I keep mine. My extension cords have a similar fate. Man, I need to become more organized :lol:
Ole Slewfoot
Freedom, CA
I have a trolling sort of shopping basket/shop cart thing, and I hang extra bunjies from its metal baskety bits. It works pretty well for keeping them untangled, and i know where to look when I need one. The ones in the truck however usually seem to have a death grip on 2-3 other items.
astrohip
Brenham TX
I've recently been organizing and finishing out my barn, and the workshop inside of it (barn: 50x50, shop: 12x24). I posted pics of a workbench and lumber rack I built in other threads.
Here is how I hang bungee cords, on the far left in this pic. It's simply a short piece of lightweight chain screwed across the gap between two studs. Cords hang off of the chain.
I also have lots of ratchet straps. I keep them rolled up, both parts together, then use a plastic tie to keep them rolled up. They're sitting on a shelf of a shelving unit in the barn area. I keep a dozen different types & sizes.
