Elroy is easy as they come. Ya ready?
The phone rings at the Holmberg residence.
Hello.......
Hay Buck, This is your good buddy Elroy. I need you to come over here and help me change out the thermostat on my neglected Toyota with the aluminum manifold.
Sure Elroy I'll drop everything I'm doing and be right over.
So first off Elroy and Buck drink like 57 beers. Tell a bunch of lies and THEN we open the hood.
And Buck says: Why Hell Elroy this job is going to be a piece of cake. The bolts are right there. Hand me that big 1/2" breaker bar.
See I told ya this was going to be easy. Look Elroy the first bolt came right out. Now let me get this second bolt.........oh **** Elroy. I snapped it right off.
Well you dumb *** you should have listened to Elroy and left the beers at home. Give me that damn wrench.
So here is what happens. The total clamping in the joint is developed by both bolts. By removing the first one totally you transfer all the clamping force generated by the gasket into the single remaining fastener. This extra load causes the friction to go up and snaps the bolt when yo try to remove it. Now if you follow the Elroy method of beer drinking. You only
partially loosen the first bolt THEN loosen the second bolt. That way everything come out in one piece.
Try the Elroy method next time and see if it doesn't make the beers a little more enjoyable.
