How do you wash your tools?
Andrew360
How does everyone clean their tools? Stuff like sockets, ratchets and wrenches. How do you clean the dirt, grease and oil off?
Sent from my SM-N910T using Tapatalk
DSLTRK
PHELAN, CA
I leave them alone unless dripping oil, I guess any ol shop towel does the trick.
Leaving them dirty- Its a good rust inhibitor.
JAKE-THE-TOOL-MAN
Bremerton, WA
I just wipe them down with a shop towel to get the oil or grease off. If they get too bad I spray them down with LA Awesome from the Dollar Tree and wipe with a shop towel.
dogdog
wd-40 and shop towel for normal stuff when I want it to look pretty.,.
A
Andrew360
Thanks! I'll try a few of these methods out.
A
Andrew360
I usually just leave them be but I'm selling some tools and want them to look pretty [emoji6]
A
Andrew360
Looks like I'm gonna have to pick up some more brake cleaner haha
disston
Silver Spring, Md
Wipe with a rag as needed. WD-40 sometimes. Use a small screwdriver to scrape the gunk from inside sockets. Older tools that are prone to rust might get a coat of regular oil because WD-40 will evalorate. Any tools with plastic handles the WD-40 will clean up the stains on the handles quite well except for scrapes and dings in the plastic they will look brand new.
Careful not to destroy the patina. It is irreplaceable.
A
Andrew360
I'm mostly cleaning snap on tools so I hope I'll be ok. They were drenched in oil for some reason.
mattblast
Bridgewater, NJ
I clean tools and handles with lighter fluid. Removes dirt and grease and doesn't leave an oily residue.
Usually I squirt some on a piece of paper towel and wipe the tool clean. Lighter fluid is also great at removing adhesive.
A
Andrew360
I'll try this too. I've used lighter fluid to clean other stuff with success. Especially adhesive like you said.
WhiskeyRanger
Depends on what tools and what's on them. At home, its rarely more than a wipe with a (probably oily) rag. At work, I use some cleaning wipes that I found at HD or Lowes. Most of my tools at work have plastic handles (pliers, strippers, channies, etc) and get covered in dirt and carbon instead of just oil and road grime. Plus I can keep them in my tool box and just wipe everything down at the end of the shift if I was working on something particularly dirty.
ssdave
Eastern Oregon
Wipe down with a rag, put them away. If they have something that won't wipe off, I dampen the rag with paint thinner or coleman fuel, that usually does the trick.
APEowner
Sunny, New Mexico
It depends on how dirty they are and what's on them. In order of preference I use clean rag, Simple Green, brake clean or if they're really bad the parts washer.
ttpete
Dearborn, MI
That's an expensive way to buy naphtha. Coleman fuel is the same thing and a lot cheaper.
Philbert
WD-40 paper towel. Sometimes a toothbrush to clean the grease/dirt out of the stampings, especialy the part that says "Made in USA"
DSLTRK
PHELAN, CA
I wouldn't use Brake cleaner, since some sockets are painted in the drive/fastener end for rust prevention, like SK/Armstrong tools. Brake cleaner will ultimately destroy that coating.
Brake cleaner also gets rid of the oil film. Unless you have a heated garage, there is a higher propensity for corrosion to form.
rockinacummins
Wapanucka, OK
I just use that cheap supertech stuff that Walmart tries to pass off as penetrating oil. It works good for cleaning tools, but not much else in my opinion.
Empty Pockets
Rural New York
I buy WD40 by the gallon and use it with a trigger spray. A squirt or 2 on a rag usually does the trick. I may check out the lighter fluid/coleman fuel trick, though
Sent from my SCH-I535 using Tapatalk
mjoekingz28
Mississippi
What is the deal with brake cleaner? That stuff is basically for cleaning new rotors before installation.
How bad are your tools that you have to cut right to the chase and use brake cleaner. Why not just cut out the middleman and just use bleach or sulfuric acid.
dclassical
I wipe them with a rag before putting them up, at the end of each day that I use them. Nothing more.
Monte
Germany
:D ;)
zmotorsports
Northern Utah
Nothing special here, just a standard shop towel, I use Kimberly Clark Wypall X80's in my shop. I will usually hit the towel with a shot of brake cleaner enough to moisten the towel and wipe them off as I am grabbing them from my tool cart and putting them away in my tool box. I hit my screwdrivers first, or anything with plastic handles) prior to spraying my towel with brake cleaner. When putting tools away I go category by category to speed things up, like wrenches then extensions or ratchets. This way I only have one drawer open at a time and it goes much quicker.
When I have an exceptional greasy job and grease and grime get into my sockets, I take them to the solvent tank and wash them out prior to putting them away. I hate sockets packed with grease.
Mike.
monkeyspanners
Oxford, UK
If only mildly dirty, one of those degreaser hand wipes, then dry with paper towel, if if really bad paper towel and some methanol.
I have some stuff in an aerosol called Grease Gobbler which will move anything but also dissolves paint and plastic though its good for moving glue etc.
jerseykat1
Central New Jersey
it cuts through grease, grit, grim and oil very effectively.
Todd.Brock
Cincinnati
This is the only reason that I use WD 40. It cleans, isn't to harsh to discolor screwdriver handles, or plastic , smells nice too. It don't lubricate or break stuff free worth a ****, but it's a good tool cleaner. I have a gallon of it and should last until i die.
A
Andrew360
So the concensus seems to be to use wd40 as it's not going to risk damaging whatever you're cleaning if you had used brake cleaner.
APEowner
Sunny, New Mexico
It's a zero residue cleaner that comes in a convenient can and cuts grease quickly. When I clean my tools it's so that I can get ready for the next job as efficiently as possible. I don't have time to lovingly polish them (not that there's anything wrong with that). I just want to make sure that the sockets that I used to tear down a leaky old high mileage engine aren't going to get grease and dirt on the interior of my wife's car if that's the next thing I'm working on.
Tron
NoVA
Brake cleaner and a blue shop towel. I really only need to clean my sockets after an oil change.
