How does this disconnect work?
Smiles79
Northwest Missouri
I've posted about my pole top disconnect previously in regards to hooking a generator up, but now I'm just mainly curious how power flows through it. It looks to me like power comes from the road to the disconnect, down the pole to the meter, back up from the meter in the same conduit (this doesn't seem right but I only see one conduit going down the pole) then to the house. Does that sound correct?
Which side of the disconnect is the meter on?
LXCam
I’ve got 40yrs in this trade and I’ve never seen anything like that. Then again I’ve never really been a resi guy either.
I’m sure it’s nothing more than a disconnect. It looks to me like the actuating lever is on the right, what’s at the bottom of it? If it is, up or down should open the disconnect if that’s what it is.
After posting this the other picture finally loaded. Sure as heck, that’s what that handles for. Do you have any idea how old this service is?
RPH
Michigan Thumb
Meter could be reading from ct's current transformers. Conduit is to small for main wiring. Need to call your electric company.
This and handle is connected to a disconnect on the secondary side. That will isolate the feed from that point.
Better pictures front on their angles should show it.
sparky 1971
Central Iowa
That is not a feed thru meter. As said above, the conduit is too small for 2 sets of conductors
Meter is only reading current from the CTs in the disconnect.
Firebrick43
West central Indiana
There are quite a few pole top disconnects in the surrounding areas, mostly installed with above ground wires to wooded areas which is common here in the creek valley. The REMC is really pushing below ground leads off of the poles with the transformer setting right beside the meter base . This has been pushed for 20 years here and only recently have a seen some pole transformers/disconnects because they have been having issues getting the ground set transformers.
It took 4 months for duke to get a ground set 3 phase transformer for a remote fill site that was built in march for our company.
fitter30
Peace Valley,mo
Main wires run through a current transformer get converted to watts for the meter. Like a clamp on amp meter. Jaws around the wire and there's a read out.
Bert_
NW Iowa
It has a current transformer. Looks like a 200A Burmeister.
I've got a couple used ones at the shop. I'll grab a picture of the inside sometime
Bert_
NW Iowa
This one had most of the wire pulled out for whatever reason but you can see the ct and the terminals of the switch
Smiles79
Northwest Missouri
Thanks for the info everyone! Would it be easy to have an electrician come out and run a separate feed for a future shop? Or would I need a disconnect that has two breakers; one for the shop and one for the house?
Bert_
NW Iowa
What are you running? Underground, overhead? Either way you don't need anything additional, a single disconnect for everything is fine and much more economical. Crimp the new wire in on the load side of the pole top along with the wires going to the house.
Bert_
NW Iowa
You don't run anything inside the pole top. Even when they are new it comes with with 3' of wire already attached. All connections are crimped together in the air.
Bert_
NW Iowa
H tap is best, but you do need a crimper. Any electrician that does poles or overhead wiring will have one.
Bert_
NW Iowa
You could use a split bolt but they aren't a very reliable connector when out in the weather
Bert_
NW Iowa
Yes if you are going to trench a wire just leave plenty of wire at the bottom of the pole. Could be ran up and connected in an hour. Hopefully you already know the electrician. It's definitely not a job I would give much priority if I didn't know the guy
