How has Your Epoxy held up to Floor Jacks?
Rustyd02359
Seeing this is one of the biggest heavy items I may be using or sliding around a lot in the gi'rage I was wondering how differant epoxy coated floors held up to it? ANybody have rustoleum on theirs for awhile?
-pru-
Midland, MI
Go Multi-Coat...
I have a single coat (barely) 3 1/2 year old ICI epoxy. Painting contractor applied it as his last job for our new home. They did a great job with prep work, but skimped when it came down to the putting a "full" single coat on the floor. They underestimated how much epoxy it would take to cover exposed concrete on the side walls which led to not having enough to put a "full" coat on the actual floor. This only became apparent a few days later upon inspection at which point we were ready to move in. Do not get me wrong, the floor is definitely coated; there is just areas were you can tell it's thinner (raw concrete just visible). I'm still kicking myself for not having the painter come back and put down another "full" coat.
Point being that this "95%" coat is just not enough to hold up regular use. It has not lifted per say, but will mar / come up when engine hoists or floor jacks are "dragging" across it. Not much I can do at this point but re-prep and put down another coat.
Which brings me to my recommendation; go with at least two coats if you plan on doing any kind of "heavy" work...
ersatzs2
Mercer County, New Jersey
Very happy with the Epoxy-Coat finish after two mos. of use. No jackstands yet but I've dragged some heavy benches and other equipment around and it is pretty unscathed.
boiler7904
NW IN
I saw a magazine once where they suggested wrapping the wheels of a floor jack with a bike tire tube cut and glued around the circumference of each wheel to lessen the impact of the wheels on the floor without affecting the lifting ability/stability of the jack. Sounds like it would work.
89vert
Lotus Land,Canada
I used 3 coats of Rustoleum Industrial Solvent based epoxy .Been down about a year , looks great .
