How hot is too hot for an air compressor pump?
R-mm
I have a California Air Tools 2hp 240v oiless compressor (10020C-22060) that has no published duty cycle. I take readings of the heat sink with my IR thermo occasionally. I will call the company on Monday to see what they recommend but wanted to ask you all - what would you consider too hot for the pump heat sink or air outlet?
R
R-mm
If i go easy, 190f. If i push harder easily over 220f
md21722
Mt Juliet, TN
My Champions typically run upwards of 300F on the head. Not uncommon for the discharge tube to be around 270F. My Jenny/Emglo's were pretty much the same. Both have 80% duty cycles.
redmondjp
Redmond, WA
If it bothers you, add a fan to force more air over the compressor head; it will run cooler. Even the $20 box fan from Walmart directed at the pump will help, even after the compressor turns off it will continue to cool it.
R
R-mm
Thanks, great info.
Lelandwelds
Central Texas
The standard answer is:
A. put a cooler on it.
B. Change the oil more often
Doesnt really apply here. I have an off topic question. How do you like your compressor? I have been fascinated by how quiet those machines are. I dont really NEED another compressor ( esp a tiny one). But, I see that pump on brands all around the world and I wonder if maybe I should find some room for one.
Would you buy it again?
R
R-mm
It was my second from Cali Air Tools, I like them both a lot. The low noise thing is really really true. It is oil-less FYI. Alum heads. I haven't really punished it so I can't say if its suited for heavy use or not. Looks very nicely made though.
Rich+
I have the 110v version of that compressor, and don't exercise it enough for temperature to be an issue. Did you ever contact California Air Tools? I would think oil-less has less temperature tolerance, although the sleeves are teflon (melts at 620F).
I do like the compressor, although I regret not going for the 15 gallon version as it will hit 150PSI instead our 125PSI. Not that I need that extra pressure... but bigger numbers!
R
R-mm
I did call them and got a so-so satisfying answer that the "max" duty cycle is 70% but they "recommend" 50%. I pressed them on why its not in print anywhere and the guy gave me attitude.
