I recently acquired a nice, used set (8 pieces) of ¼" shank Snap on Carbide burrs for a good price off of flea bay.
The label specifies optimal speeds for each bit on two different types of metal (iron/soft steel and stainless steel). The optimal speeds range from 16,000 to 33,000 RPMs and it says tool damage may occur if not running at these speeds.
I don't use these professionally - I am a hobbiest working on vehicle modifications and other do it yourself creations/inventions. I frequently find myself needing to enlarge a hole, trim metal brackets, etc, which is how I use the bits. I use them practically every week, but not heavily.
Right now I have a cheap HF die grinder so am not even sure what RPMs it actually puts out. And, searching around, I can't find ¼" air die grinders that spin at 33,000 RPMs...
Two questions for the experts/pros here:
1) How important is it to run these bits at the recommended RPMs
2) IF important, can you recommend a reasonably priced air die grinder that can control the speeds over this range (16,000 - 33,000 RPMs)
Thanks in advance from a novice trying to learn!
