NewShockerGuy
My wife's townhouse is a rental and we are updating things for the new tenants. The kitchen area needs a little sprucing up. I wanted to go with granite countertops to replace the 20 year old plain almond straight cut laminate but after discussing the size, installation, sink and cutout it would be in the tune of $4500 it's just not worth it considering in about two years we are totally gutting the kitchen and redoing it....soooo we are going to go with laminate again but the ones that have a nicer beveled edge and one that looks like stone. I'm actually quite surprised at the quality compared to what the builder did in the house 20 years ago. They have really come a long way.
Now we want to save the cabinets currently, where in two years ripping stuff up isn't an issue, I do not want to destroy the bottom cabinets when removing the old top.
What is involved in removing it? Is laminate normally screwed into the bottoms via screws coming through the tops of the bottom cabinets, is it glued...etc?
What is the best way to remove it without destroying things? I believe it has a small backing of about 3" on the wall so removing that is OK, and I am fine patching/painting the back wall. In fact we are probably going to go with a backsplash which I will do while replacing the top.
The counter top is a standard L shape and is not huge only because the sink, stove and fridge are also there so when we were at Lowes I think we'd need only 2 pieces to do the L (one straight with an angle cut, and then a smaller piece completing the L shape). Of the tune of about $350, which is cheap. I would have to make the cutout for the sink, what is best to make the cut.. router, jigsaw?
And lastly what is the best way of re-attaching new countertop, and do they normally need shimmed or anything like that?
Thanks much,
-Nigel
Thanks much,
-Nigel
Pretty sure you could google many horror stories.
