Technically, the largest disc the drill press can drill to the center of.
In other words, the throat depth- the distance between the center of the spindle and the front edge of the column. A drill with a 6" spacing would be a 12" drill, 8" would be a 16" drill, 10" is a 20" drill, etc.
And it's not necessarily new Harbor Freight doublespeak either; my circa-1909 Rockford drill press has "20 in. Drilling Machine" cast right into the column, and it has a 10" actual throat.
Doc.
The first answer is correct. It is the distance from the spindle center to the column, not twice that distance.Twice the distance between center of spindle and edge of column.
Indeed, same as swing on a lathe.
You may be correct in Europe as that is how they measure a lathe, not sure if the same applies to a DP over there. In America it is the diameter of a disk that the lathe can swing or a DP can drill the center of. Europe measures the radius.
lg
no neat sig line
Awsome, we have a genuine internet blogger among us.
