Junkman
I am slowly trying to understand radiant heat, and what I can't understand is how the temperature in the Pex lines is regulated. The plumber has said that he will be installing a Sparcomix nonn electric mixing valve 3/4" AM101R. I did some reading on the web, and what I don't understand, is if it is introducing cold water to the system, to drop the temperature coming out of the boiler, what becomes of the extra water? Does it get dumped to waste water outlet? Also, some talk about a 3 way valve, and others say to use a 4 way valve. Which is better? I want the floor water temperature to be no more than 120 degrees, so the wood doesn't get too hot, and start shrinking. He is also installing floor temperature thermostats. Below is a link to the PDF installation instructions.
Mixing Valve:
https://forwardthinking.honeywell.c...ll/mixing_valve_tech_lit_and_installation.pdf
Thermostat:
http://www.uponorpro.com/~/media/ex...01-501s_insthb_3_07.ashx?version=062220160829
What I don't understand is how this mixing valve is going to control the water going out to the floor, since the water in the boiler is 175 degrees. I asked if there was going to be a mixing tank, but he said that the system "as designed" doesn't need a tank of any kind. Where does the cooler water come from to drop the temperature?
Mixing Valve:
Thermostat:
