How long should your epoxy garage floor last?
Mount Pisgah, Massachusetts
After 4 years mine is lifting at the edges, chips very easily and the tires leave a brown tire print in it when the cars are parked for more than 2 weeks time.
Is this normal?
It was a new build and the floor had cured for about 16 months before being profesionaly coated by a company I hired.
They first shot blasted it, then primed it and let that cure for two days then base coated it and followed that up with a clear top coat one day later.
It looked real good for about two years then got crummy looking.
What to do?
e-tek
Saskatoon, SK
I'd be pissed!! Didn't they offer a warranty? I'd think 5-10 years would be reasonable if professionally applied.
dmw56
Edgewood, NM
Mine is 6 years old now. It's not lifting but show wear in areas where it get the most abuse i.e. dragging heavy stuff across it, welding, plasma cutting.
Ramblur
Central FLA
+1 except 12 years here on a Precision Epoxy broadcast system. There is
a pretty substantial mark from an alternator falling from the loft(about 9 '),
still the floor faired better than the alternator did.
TAMPAGT07
Palm Harbor, Fl
i was wanting to redo mine. do you strip your old off or epoxy over it?
I have, in the past, painted over it with an oil based epoxy. I can't remember if I purchased it at Lowes or Home Depot. I know they no longer carry it though.
I am getting ready to do mine again, but I have still not decided on a product. The floor has never came up, but I do have a few holes to fill from an old lift that I had. I also have a few gashes that I put in the floor. :beer:
nuGarage
Vegas & San Diego
We offer ten years warranty, and feel totally comfortable doing it. For a floor to last a decade, we feel quite strongly that the floor must be physically prepped and not acid etched....
Nathan
thundercow
Austin, TX
We offer 5 or 10 years depending on the price structure. With good prep and quality materials, 10 years is the benchmark...
That HD epoxy? 2.5 years at best...
Jarvis
in
Nugarage?
Not acid etched? Can you explain as i always thought you had to acid etch before epoxy goes down.
T4Turtle
MN
Instead of acid etching you can rent a machine to cut into the concrete to open the pores. Like a rotating assembly with a diamond tip blade, from what I can gather.
Anyone got a picture of this apparatus?
I would like to hear more on "real world" longevity of all the products.
A_Pmech
IL
10 years here. No peeling, chipping, or lifting.
I've had over 10,000lbs roll over it on machinery skates with no problems multiple times. Plus the usual pallet jacks, forklifts, motorcycles, cars, etc.
Rustoleum "Industrial/commercial" epoxy kits, acid etching.
tcianci
Walpole, Ma
Mine is a StonHard floor, I put it down myself over a 20 yr old really abused floor. Its been there about 8 years and beside the obvious abuse I have caused it, it seems to be rugged as all getout. This material is typically used in industrial applications and the prep that is done for it is usually Blast-trac to abrade the concrete.
XR80David
****'s its peeling... Isn't it unavoidable to leave a car parked for a long period of time and there to not be a mark after right?
Markgyver
Colorado
Ray-CA
San Diego CA
My Valspar coating is fine and I put it down in 2000. The only trouble areas are where I dropped a jack-stand and "chunked" out a chip of the floor. That would have happened with any flooring.
I'd check your paperwork for a warranty.
Ray
thundercow
Austin, TX
A picture of the apparatus, an edco dual-head grinder (being used on my garage, and the results below it):
finished here:
