How long would it take you to build this?
rharman
SoCal
edit: Dang.... Just saw that @steve w beat me to it :(
Golden rule of project estimating....
How many of <unit> will it take?
Double that
Increase unit-of-measure to the next higher
example:
  • Guesstimate: 2 hour project
  • Double the 2 - Now it's 4
  • Next higher unit of measure from hours - Days
  • So.... This project will take 4 days
Monza Harry
Windsor ON
I feel your timing seems right on! One needs to consider the material manipulation you needed to do, at 4'² easier by far than your 8' length. That is way outside our reach and adds quite a bit of Tom fudgery to balance some pieces as assembly proceeds. My initial estimate was about 8 hours and I'm not "optimized" for this work [or any other for that matter] so considering your lumber repurposing and screened bottom you did (more than) fine! Harry
Moss
Ontario Canada
I find everything takes me a lot longer than I think it's going to. Even knowing that's how it is I usually still underestimate! I'm not good at working fast though so it's not even worth trying. I'm not sure how many hours that would take me but it would be an entire day and probably most of a weekend I think.
Two Speed
Ontario Canada
My wife has lots of experience with our construction projects over 50+ years, including building our first house using just hand tools and local rough saw mill lumber. Her rule of thumb is to take my estimate of time required, double it, and add a week. She is often correct, but over the
I suspect when "we" look at a project, we somehow accurately figure out the actual build time estimate... we just leave out all the incidentals. Walking back and forth with, material moving, refilling our screw/nail container, measure twice, etc. that eats up the time we did not account for.. because, well, thats not actually building it. =-)
jar944
Northern VA
I'd say a few+ hours if done in a similar fashion (predrilled and screwed) less if it was built by a framer (within a 1" and just shot together)
DGersic
DeKalb, IL
Double that
example:
I use this. Or the simpler answer “two weeks” from The Money Pit.
