Is 90a what's required to charge EV's? Seems like alot.
. This is a storage building near our summer/hunting cabin. its normally vacant.
Well, that bit of info was never shared. When you mentioned storage building/ garage, being GJ, I think most assumed this was at your residence or home.
and you need two ground rods at the shop
Yes always good to share such infgo from start. This, said, when I'm doing something I like to think of next owner and possible resale improvements.Yeah... I probably should've started with that. Lol. Sorry.
Personally I would run #8 and use a 50 amp breaker, just bought a 500 foot spool of black for $218. Next is a spool of White.
I used #8 to run two welder circuits decades ago and put 30 amp breakers on them, due to the plug, and now the upgrade is a new breaker and plug.
Now you are going to love this. I was at a shop looking through there clearance area and picked up a partial spools of #10 green and black for $30 plus tax
Is this true? I thought NEC only required two if resistance test failed.
Sent from my MI PAD 4 using Tapatalk
The resistance test cost more than a second ground rod.
If you intend to install a stick welder make it at least 50 Amp. My garage came with only 30 Amp and I have been limping (and cursing) along with that for the last thirty years.
I ran 60 amps two years ago when the only thing I was planning on powering was a welder, but now between two EVs, a mini split, compressor, wife's animal shed, etc., that's barely adequate.
I see it's already been mentioned, but here's another vote for 2-2-2-4 MHF in aluminum. Well under $2/ft and good for 90 amps. A 60 amp breaker should be easy to find (and cheaper than a 90A) and should be more than enough.
Unfortunately I went with 1" PVC and #6 copper so I definitely can't replace with MHF. Looks like if I start tripping breakers I can get away with #4 copper for the same 90 amps (technically 85 but I believe a 90 amp breaker is allowed by code) since the panel itself is good for 100 amps. Of course at that point I'm probably close to maxing out my house service at 125 amps.I think if you searched on here the most common answer is mobile home feeder for 90a. MHF usually under half the cost to go 100a.
Tesla chargers pull 48A continuous and require a 60A breaker.
Of course, an easier thing to do might be to lower the charge rate on one of the cars if it becomes an issue.
Sent from my moto g stylus using Tapatalk
Future plans include solar on the roof of the garage feeding the house.
Yes, and to add to what Alfred said, conduit is required for the entire run, above and below grade.
Make sure you run 4 conductors, and you need two ground rods at the shop
2 grounding rods in the shop or one at each panel?
2 at the shop
Why’s that? I’m in the middle of wiring a shop that is sub fed and i was under the impression there was one at the sub panel and one at the main breaker panel. Just curious as to why you have 2 at the shop
Lower the impedance to ground. In plain english, you will have a better ground.Why’s that? I’m in the middle of wiring a shop that is sub fed and i was under the impression there was one at the sub panel and one at the main breaker panel. Just curious as to why you have 2 at the shop
Telecom shacks have even more ground rods in the ground, but that is another subject.
Interesting, makes me have more questions but I’ll go to google so as to not clutter this thread anymore
Hahaha, that's the best way to do it.Never read the full thread, but just recently I moved my service entrance TO my garage. Now I have 200a at my garage, and could easily go to 400a
Just came here to brag![]()
you can use thwn. I think all #2 thhn is dual rated thwn. its a little cheaper than xhhw-2 and easier to pull. buy your wire from a local supply house it'll probably be cheaper than the box store and they'll spool up 4 spools for you.
also, to make life easier run the outside conduit up the exterior wall and LB directly into the panel. I put my LB way down low, and then had to do another LB on the inside to get the wire up to the panel. pulling through back-to-back LBs with large guage wire is a pain. xhhw-2 made it even harder. i'd use 2" conduit and 2" LBs, minimal extra cost vs 1-1/4" and will make life easier.
