how many BTU's ????
9dreizig
I"m in the middle of my 50 x 50 x 15 steel building garage.. I'll be heating with propane.. Any suggestions or calculations as to how many BTU's my heater will need to heat it ? It won't be continuous , just when I'm working in it.. would also like to keep it above freezing in the winter however ( I live at 6800 feet above Reno, NV )
Oh and brands of heater suggestions are welcome as well
jomobco
Denver, CO
You will need to figure out your insulation first. I have R19 walls and R30 ceiling in a 64x40x14 space with a 61k BTU pellet stove which keeps it very comfy.
I'm guessing you're not 6800' above Reno but at 6800'? I'm at 6400'.
toyotadriver
Without knowing your level of insulation it's impossible to answer. I heat my 30x40x10 with open rafters with a propane 80k Mr Heater. But mine is very well insulated.
Also need to know what size and how many windows and doors you have as well as how often the garage doors are opened.
Repsolracer22
central MD
People are just throwing out random numbers. You cant get a real BTU calc without length, width, height, insulation, AND the temp rise you are looking for.
so take my place for example. 40x60x12 with r19/r38. say its coldest is zero deg outside and i want it to be 70 inside .... well that calc is about 90,000BTU. That is a calculator from an ACTUAL heating company. Reznor Heaters.
Granted it NEVER gets to be zero in Maryland. And Im NEVER going to put the thermostat at 70. And on top of that .... i still bought the 125,000 BTU version. Just made me feel good :) but its complete overkill
So 175k is beyond ridiculous for that space. In any temp/scenario. Unless you'll be leaving the garage door open 24/7
Shop Specialties
Grass Range, MT
I have been doing heating for 25 years and I am not just throwing out numbers. With decent insulation I put it at approximately 150,000 BTU so at 175,000 BTU input, you will be at about 145,000 output. Then you factor in he is at an altitude of 6,800 ft and my number is in the ballpark.
Showkey
"MEMBER EMERITUS"
Wausau WI
SS is not far off the mark.......That 15' ceiling and the altitude adds a whole nother " dimension" to the btu chart.
[/URL][/IMG]
Ironhorse74
MEMBER EMERITUS
The Pacific North Wet
Without knowing efficiency and insulation aball park is 4 btu per cubic foot in new tight construction and 6 btu per cubic foot in older looser construction.
9dreizig
Damn I hate punctuation I meant I'm at 6800 feet , above Reno.. Reminds me of that quote about helping my Uncle Jack, off his horse :)
I'll get the insulation numbers as yes it's insulated.
toyotadriver
That's not much insulation. Not sure your layout but maybe install a couple heaters? I suspect you'll need close to what Shop recommended. Two 80k furnaces at opposite ends of the shop might heat it well and cost close to what a single bigger heater would. Also, you might consider a residential heater with ducting to spread the heat throughout the shop.
