Paperman
Can anyone tell me or better yet show me how to find the number of #12 conductors in can have in a 1" EMT. 100' run with a mix of 15A & 20A. I would love to add a 50A 240 in there if possible. Teach me how to fish!!!
Havent pulled a wire yet, I would be way under that. Planning my runs well ahead of hanging steel. I would like to pull in 8-10 #12 and then also a pair of #6 for a 50A outlet primarily for welder usage. Id love to know how to do the calculations for mixed size.
All point well taken and have been thought of. This is a 80x120 building, 480D main service. It was steel tube and wire manufacturer in from the mid 50's through about 1980. All of the 480 is gone save a small GE lighting transformer A new 15KVA 480/240 transformer mounted mid building feeds a small distribution panel under it. From there that panel feeds 3 others in corners of the shop. These final outer panels feed all the 240/120 needs in their respective area. Most of this is new install as all that was in place for the last 30 years was lighting and a few scattered outlets along with about 15 fire hazards of scattered scabbed lights and receps. The 1-EMT is salvaged from a long gone 480 run. The actual run in question is about 80', 10 up 60 over and 10 down. All my big stuff is 480, lathe, mill, drill, air comp., grinder etc. So I hope this clears a bit of what the shop is and what I am doing. I need to run a 250 mig, 180 tig, waste oil furnace or a 2 post lift. That's the extent of the big loads I PLAN to have. Might have parts washer with a fairly healthy heater but that is going into a different section of the building. Lots to do and not much time before I see snow!!
I appreciate the help from all yall.
I have both already. My Miller Mig is about 20 years old and the Tig is about 10. Both have served me well and will keep doing what they do a long time I hope. One big 480 stick machine for the heavy work. Idealarc 300, not light but it is smooth!!
