bagged89s10
I need some help with my garage lighting layout. I have approximately a 19' wide x 21' deep garage with 104" tall ceilings.
My garage is a bit messy as it's a work in progress, but it's time for some lighting. Here are some pictures to get an idea of my space. Right now i only have one 4ft t12 fixture which is far from adequate, not to mention the old fixture won't turn on when it's really cold out.
I will be hanging a 4ft fixture under this 30" deep shelf for direct lighting over my lathe.
The back wall has about 14" deep shelving. the toolboxes stick out about 22" from the wall and I want to have enough lighting in that area.
there is going to be a 24" deep shelf above the cabinets which i will be hanging lights under. My long workbench with the drill press is 27" deep
I plan to use these t12 light fixtures @ $12 each and remove the ballast so i can use ballast bypass led tubes.
Searching online I found these for $9 a piece. they are 18watt 4000k color temp led tubes.
https://www.earthled.com/products/l...wPh_iuvRx0j4UMWBoCtN_w_wcB&variant=2174807620
Will 4 or 6 ceiling light fixtures be enough? How should i lay them out? I also like to work out in the garage at night with the doors open. What should I do about lighting the area under the garage door when it's open?
Thanks for your help.
