How many Lights for Shop
StaggeringGoat
Oregon
You're going to need a HELL of a lot more than that. I have ten 2 tube T8 fixtures in my 40x60 and I still need a lot more.
hansen1
Colorado
I have twelve 4 bulb T-5 48" fixtures in my 36x48 with a 14' ceiling. I think the lighting is just about right. Granted I don't turn everything on all the time but have the flexibility to have as much light as I need for a given need.
Not having enough light is tiring on the eyes and can be a safety issue.
WILD-BILL
Brook Park Oh
I have 7 4x48" fixtures in my 21x21 garage and I'm real hppy with it.
4 fixtures in a shop that size wont be near enough.
J
jake1086
Williston ND
I was thinking 4 rows equally going the length and then taking either 4 foot or 8 foot units all the way down the rows 8 feet or 4 feet apart respectively.
so in an 80 foot long shop each row would have... 5 8' footers so 20 units total.
I want it to be bright I HATE dim shops
Bigrhamr
North Idaho
http://www.visuallightingsoftware.com/
Download the trial version and don't guess! Your 16 ft ceiling will make a big difference. I bet you could use T5's without a problem. This software allows you to pick some difference fixtures and see how it works, including many layout options.
jvitez, I downloaded the 30 day trial version and what I got is just for roadway lighting. Did I maybe miss something or have they changed what's available on the trial?
I'm about to take the plunge and order my shop lights. The plan for a 40'x60'x17' tall main bay is 6 lamp t5's, 15 of them in five rows of three going across the 40'.
I'm thinking about buying from here as recomended by a local commercial electrician. Anybody have comments on them?
http://www.e-conolight.com/linear-f...p-commercial-linear-fluorescent.html?___SID=U
Steevo
43.49600, -112.04300
I used 17 of the 4x4ft T8 fixtures in my 24x40, with 12' ceilings.
Or 56 sq ft per 4x4 fixture. It is just right, light wise.
at 16' ceilings, you need more lights to get the same work-level lighting.
GeorgiaHybrid
Extreme NW Georgia
Just built my 32x52 shop and used 8 ft fixtures with (4) 4' T8 bulbs in each one. 8 lights are distributed across for general lighting with 5 dedicated in each bay. That's a total of 23 lights when all 4 switches are turned on. I have 15-8 ceilings and although everyone laughed at me for the lights I put in, they all like it now. No shadows, easy to see and you only turn on the lights you need.
J
jake1086
Williston ND
well I ended up going with the 6 bulb fixtures with those skinny little bulbs... not sure what there called... I'll see if its bright enough ;) electricity gets turned on friday hopefully :D been a long road excited to show GJ
fiveohpatrol
Bloomington, IN
I have 20 4-bulb 48" T8 fixtures in my 40x40x12 and it is perfect. I thought it would be too bright, but it's great.
For your shop that's twice the size and taller, I would recommend at LEAST 30 of them.
brownsl
Southwest OH
I have a 32x52x12 garage and I used 4 lamp 4 foot T8 tandem fixtures with a total of 24 fixtures on three switches. It is very bright when they are all turned on and I love it. The electrician thought I was crazy to put this many lights in the garage but I think it is perfect. I used the Visual software to get everything placed just right so that I have a nice distribution of foot-candles. The color temperature and CRI of the lamps have a large influence on the quality of the lighting in the space.
John in OH
SE Ohio & Eastern Virginia
I installed 12 of the 4 bulb, 8 ft. T8 strip fixtures (8' long, two bulbs end to end) in my new 34x54 shop with 12 ft. ceiling and love them. The strip fixtures are flush mounted to the ceiling and I doubt that they extend further down from the ceiling than 4 in. See photos and Postings #91 and #93 of my build thread,
http://www.garagejournal.com/forum/showthread.php?t=98038&page=5
I have additional task lighting at selected locations in the shop such as over the workbenches and welding table.
Unless you want to spend a lot of additional money, you should avoid the T5 bulbs. They are technically a better bulb, but at this stage of lighting development, I don't think the T5s are worth the money.
