How many wrench sets are too many
anytool
I've found myself creeping up on 3 sets of conventional metric combinations wrenches as I upgrade. Once I factor in my ratcheting wrenches it feels like alot. Do I start building multiple boxes, keep them all In one, deep storage, or liquidation? Looking for input
2ndGearRubber
Pittsburgh
Storage for the cheap or rarely used ones. Sacrificial wrenches need bent with a torch or cut/welded, so I keep a full set of combos just for that. Problem with upgrading is often your old stuff has such little value selling is hardly worth it.
IMO, if you're buying duplicates of the same item, like standard combo wrenches, you run into the wall about 3 sets. You can only use two of the same size at one time (rare), so that "justifies" 2 sets. The third needs a zip tie through the box end, and stored away. Once you get into various styles like.double box and ratcheting, IMO, 2 sets of combos is plenty, single sets of everything else. Now, if you have flex head ratcheting and straight fixed ratcheting, and fixed head angle/reversable ratcheting- those are 3 different tools. Whether it makes sense for a non-pro to have that level of minutia, that's a different story.
I bought a carry tool box from harbor freight to stick that kind of stuff in. 7mm 3/8 drive impact sockets, wrenches ready to die for the cause, etc.
justtools
Firearms and wrench sets. Never have too many. Everything is put together with nuts and bolts and needs repair. Also never know what Putin is thinking when he is done with Ukraine. That is Why Number 1 is important
A
anytool
You can have too many when you run out of space to store them all. Why fill up a box with combo wrenches when one could use the funds and space for more variety?
It has more been a progression from harbor freight, to tekton to snap on. Im not a fan of "good enough" for long term tools. Im not trying to stack em deep. The cheap stuff just has minimal value on the used market. Although I suppose I could build out a set of Travel/loaner tools.
A
anytool
I like the hand carry box idea. I recon I could use it as a travel/loaner set as well. Even though I already have a cheap set of tools in most every piece of equipment I own. (4 plow trucks and 3 Tractors)
VolvoRyan
Kentuckiana, USA
I think I have between 7-9 sets of wrenches just in metric for front-line use. As I get older, "work smarter, not harder" has become an important philosophy.
Wrenches condense pretty well into a tool box, and my tool box is probably smaller than most of the folks here.
Stuff that doesn't get used, either gets repurposed into other tool sets, or stored deep.
It's good to have some old wrenches/sockets around for when the abuse needs to happen. :)
-Ryan
RedneckWelder
The Ghetto Kingdom of Methlandia
A set of good combos, a set of cheap combos for backup or modifying, stubbies, obstruction wrenches, crowfoot, flarenut, angle, service, ratcheting of a couple different types, and offset box wrenches. It’s all in my box.
a good storage method to keep sets compact, especially lesser used sets is wrap up or get some coiled wire like spring guard on a hose and store the wrenches vertically and close together
CHI_Tool&Die
Chicago, IL
I had the same problem. You’re going to have to have an honest conversation with yourself about needs and wants. It’s hard. I drug my **** for weeks. IMHO, keep the best quality ones and dump the rest. I have two sets of each at the house - one 12pt combo metric and one 6pt combo metric and two 12pt combo SAE. I have another of each at work plus my metric DOE. I figure that basically covers it outside of maybe getting some stubby or ratcheting sets in the future should the need arrive. Everything else I donated to the local community college. Turned out to be a good thing. The kids didn’t have a lot of community tools for the engineering tech/manufacturing program so I know they are being used. I’ve started to do the same with my ratchets and sockets. God help me though if I ever leave the trade because I have a ton of work tools and they are all nice so I’d struggle deciding what to keep for the house. 😂
dr_clyde
Holland, MI
I keep basic sets of tools kitted up for various machines and applications. I probably have 4 or 5 sets of wrenches, sockets, pliers, screwdrivers, etc.
Main personal box at the shop. Home box. Portable box. Shop community box.
The mill and lathe have their own dedicated sets of whatever is needed.
m6z
Missouri
Tools for tots?
I'm slowly building a set of tools for my toddler. So far I've got a set of Carlyle long pattern combos packed away in a Capri backpack.
bigjeff94
USA
I use a similar system. I hate having to pull tools from the main box to work somewhere else. So i have a dedicated portable box, and if I end up carrying the portable box to the same places or machines over and over again they eventually get their own dedicated kit. This is what works best for me.
Al Borland
Extra/unneeded tools go in the "Tools for Fools" box for work. Others go in the "I might need a wrench to mutilate" pile.
Some are in the house box, some in the garage. More in the truck, some in the car.
Probably 6 sets of Metric, 10 of American.
larry_g
oregon
I would put the number at about 20 sets for being able to do most work. Now consider my first tool set I bought was over 50 years ago and it came with a set of combo's, double open end, double box end, and a set of ignition wrenches. Over the years I've added long and stubby sets, offset and straight, a couple of combo sets to have in the different areas/rigs. Now double that for metric sets. Some tubing wrench sets, sets of adjustable wrenches. Then if you add in racheting, and socket ends, which I don't have You can easily pass 20 sets.
I think you should re-ask your question to be " How many DIFFERENT sets are out there and how many do I need?"
lg
no neat sig line
M635_Guy
NC
a million.
if you have a MILLION wrench sets, that's only one too few.
ftfy
I've played the justification game pretty strongly here, so there's some overlaps, but also some specialty. For example, my XFrame set is my zero-offset ratcheting and my grumpy-fastener open end (I forget what SK calls their Flank Drive Plus equivalent nut-biting design) (nut-biting - #thingsIonlysayonGarageJournal). My Tekton combo set is what lives in the cart and does everything. My Hazet combo set lives in the tool roll that travels with my old BMW (and hopefully is only used on other people's cars...). Etc.
I also have a complete metric and SAE Craftsman set from the post-China transition in my "family" tool cabinet (can be used without asking kind of thing) as well as a set of Husky flex wrenches that I didn't like much for some reason.
I try not to count the specialty stuff (flare, long flex) against the total. The only SAE set I have is the Craftsman, so I give myself bonus points for my self-restraint...
M635_Guy said:
I've played the justification game pretty strongly here..."
Okay.... honestly, I have no clue how many sets of wrenches I have here.
I know I just ordered another one today, because I'm trying to complete a set.
I don't really collect that many brands of wrenches like some guys, though.... not like BlueBomber... I only have Indestro S-K Bridgeport Danielson Wakefield Niagara Gilfillan.... and a few others.
So maybe a lot of wrench sets, but not really that many brands.
Or maybe not. :dunno:
M635_Guy
NC
Threads like this makes part of my brain start taking stock. At which point another part of my brain says I should just have a vague idea and be content with that. The latter usually wins...
ecotec
I don't understand how someone can have too many sets of wrenches. Maybe I am just dense.
I do... because those are my favorite estate sales. I like huge volumes of lightly or barely used tools. So many estate sales are hoarder sales to some degree.
The more sets that a hoarder has, the higher the chance of finding an unused or barely used set.
Boogerman
aspen cove hill
I found this article in my local newsletter about this topic:
Call that?
A fair START! :bounce:
Read it. Nice he interested, but sad. HF box blah tools makes feel like "I've made it". Not used tools I wear out use daily. First think "amateur". Then, think different way life. Big cheap green box tools less capable my emergency carry truck box.
CS454
- Snap On FD/FD+ combis to 1-1/2" and 25mm
- Snap On FD+ reversible ratcheting to 3/4" and 19mm
- Snap On FD+ four ways to 3/4" and 17mm
- Mac Precision Torque Combi to 1-1/4" and 32mm
- Matco 0° Ratcheting to 1" and 25mm
- Sunex Combis to 2"
- Sunex four ways to 2"
- Craftsman USA combis to 1" and 18mm
- Mastercraft stubbies to 7/8"
- Crowsfeet to 2" and 19mm
- 7 or 8 adjustables of various sizes
Not done yet...that an answer?
Dakotadadv8
Nice inventory. Snap On FD+ reversible ratcheting metric are really nice. Maybe overkill for DIYer if already have regular Snapon combos FD.
CS454
100% overkill. I got them on student plan pricing and would never pay retail for them, but that argument goes for anything SO on that list. Dream is still to build out the SAE SO set to 2".
