I have a small two car garage, 19x21 with 7.5ft ceilings. It has no windows, two 8 foot doors(wood slab type), and sits under the master bedroom which is insulated and conditioned year round.
Once I finish insulating the two exterior side walls and sealing up the doors as best I can, what kind of BTU range should I be looking for?
Due to HOA restrictions, I'm thinking of going with a portable ac unit that can be vented through a 4 inch dryer vent installed next to my actual dryer vent. Anything more obvious outside like mini-split or "window unit mounted inside"-vent would probably not work. For heat, I think a smaller electric heater (5k watts) would work, and I'll have a 60amp sub-panel installed to power all of it.
I was thinking 12-15k for cooling, ideas?
thanks,
Andrew
thanks,
Andrew
