PCMusicGuy
As I already replied, by using slim breakers you can easily add a 220 circuit to your full breaker panel at a cost of about $11 for a 40A breaker, and a few bucks for some slim 110 15A breakers to make the room for the 220. I have done it multiple times, it is very simple. It is certainly easier to just grab a 110 compressor and plug it in, but you will probably be happier with a beefier 220 unit and it can be done with your budget. Also consider that many quality 110 compressors will not run on a 15 amp circuit, which your garage probably has. So, at that point you are running a 20 amp 110v circuit anyways, may as well run 220!
You guys don't seem to understand. He is saying that adding 220V breakers is not an option at this time. He likely doesn't have the time or knowledge to do it himself or maybe none or compatible with his existing panel. He may also not have a friend nearby who could help him avoid electrician costs.
Anyway, the highest output rated compressor I'm aware of for 120V (20amp) service is the Quincy Q12126VPQ. It is rated at 7.4CFM @ 90 PSI. It is several hundred dollars more expensive than the Husky you are looking at and the extra CFM may not be worth nearly twice the cost. I'd say get the Husky and be happy if the higher flow rates aren't really necessary.
