Plastikosmd
- Joined
- Nov 17, 2016
- Messages
- 1,254
2k or a bit more for 3k sq feet, (25’+ ceilings in about 2k sq feet) held at 65 degrees
North Texas, foam ceiling and r30 bat walls with 1/2 osb walls 1,000 sq foot. Mini split $8-9 per month usually have to use about 3 times per week, If it is 55-60 outside temp. It doesn't take much to get it to 70For those of you who aren’t earning a living from your shop/garage:
Same. Boiler, water heater, softener, plumbing, is all in my garage too, so not an option to not heat it.It's hard to quantify my shop radiant floor heat usage since it is a separate zone on the boiler.
The boiler has to run anyway to keep the wife warm ( and me)
Shop is kept at 58F all winter.
my guess is around $200 extra a year (maybe more)
Most insurance company's wont allow a wood stove in a garage these days.North central Ohio.
I heat with wood that I cut at my parents. So I have no cost for the wood itself. However, I do have a fuel cost for the saw, my truck and JD. I probably spend around $100, maybe a little more, maybe a little less.
Over the years, I have updated the wood burner with a new one and two years ago, bought a new saw. Wood burner is a way better unit and WAY more efficient than the old monster that I had.
Mine does, they know about it and have no issue with it.Most insurance company's wont allow a wood stove in a garage these days.
Nothing.The emerald ash borer has killed dozens of ash trees around the farm plus the normal attrition of other species,I can’t burn it fast enough.most will rot before my shop stove ever starts to want for fuel.For those of you who aren’t earning a living from your shop/garage:
If the shop/garage provides therapy= you enjoy being there ... don't do what I did and wait too long to get her properly heated.
Air leakage is more important than insulation.Same story here. Insulation is key!
I believe 12" insulation is R40,,,that was standard for attics when I spent a season insulating homes. Insulated garage doors are usually R10 at best...Lot of interesting comments on "Insulated".
Leads to the thought of if R19 in a 6 inch wall is a standard.
When you put the same R19 in the Ceiling, then on top (attic) add 6 inches more at 90 degrees to that.
What does the "R" value become?
I ask because following the comments on low heating costs for a 900 to 1000 sqft. Shop, I think my Cost is too high?
Also, what is the insulation value of the Garage Doors most people have?
No expert here just a homeowner. I've always just added the "advertised" R values together. Right or wrong, I don't know.Lot of interesting comments on "Insulated".
Dang. I don't think I've ever been in a house that huge!I'd estimate average of 20-50/month during the heating season. Total of maybe $200ish for the winter?
Attached ~40x24. Heated via natural gas unit heater. Minnesota.
Don't have a way to know for sure, since I put in the heater the same month we moved into the house. So I have no historical usage to differentate the house vs the garage cost. Total bill is usually 130-220/month during the winter. House is ~4200sqft.
People who think wood heat is free have never heated with wood.I take issue with the thought that if I heat with wood my cost is zero. The amount of time spent cutting splitting stacking has to count for something. But then again I enjoy it being outside and I don't have a gym membership. Maybe it all balances out? Plus I really like wood heat.
What is an Arctic entrance?Dang. I don't think I've ever been in a house that huge!
Place I grew up in was around 1000 sq ft. Current place is about 1400.
Wouldn't mind a bit larger to have an arctic entrance and closet for cold weather gear.
Basement would be awesome too.
In the Arctic buildings generally have a first exit/entrance door with all of the locks and latches but then a small fully enclosed "porch" about 4' x 4' with yet another outside door (usually with no locks, just latches). This is done so you can close one door before opening the other and letting a blast of -40/-50 air blow into the interior, it just has to swallow the 140 or so cu.ft. of air in the "arctic entrance". You don't leave your gear in that porch as it is ******** COLD! (.i.e. closet inside as Sumboodie implies).What is an Arctic entrance?
I average using 470 gallons of propane through a 96% efficient furnace to heat my 30 x 45 shop in southwest Missouri. The thermostat is set at 45 when unoccupied and 60 when I am working. The shop has 14' walls with two insulated overhead doors, one walk through door and no windows.
