How much does your air comp leak?
arthur1920
OK,
So, I assembled the Iron pipe, ball valves, water sep, regultor, couplers and etc, joined by a hydraulic hose. My compressor leaks down about 1 lb/hour.
It was worse, I used bubble soap to check the connections and fixed the obvious ones. It's in the piping cause when I shut off the first valve it doesn't leak down..finally.
Anyway, do all your compressors not leak down at all?
Art
Lyaec350
somewhere...
Mine is about the same... 1 lb/hr at 125 psi. Less at lower pressures. It will stay above 90 lbs for a week or so. I just turn off the compressor and main valve right outside the tank every day when I leave the shop (after draining any water) and figure that's acceptable. Still holds 70-80 lbs indefinitely in the pipes which is more than enough for filling tires/blowing the odd thing off.
wilbilt
NorCal
Mine loses about 1 PSI/hour as well. That's with the first valve closed at the tank.
It needs a new check valve at the tank inlet. I took it apart and cleaned it (which helped), but it still leaks a bit.
chammyman
Glasgow, Scotland
I have yet to see a compressor thats not totally empty by the next morning
I have no idea how they manage to keep them pressurised for weeks like some on here say they do.
A
arthur1920
The compressor I replaced, would hold air almost forever as long as the coupler was good and didn't have a tool on it. It's about 25 years old, Sears two hp, 25 gallon, on wheels. I just needed more air.
Charles (in GA)
50 mi south of Atlanta
I close the ball valve at the tank outlet, and the compressor doesn't leak, neither my little 12 gal, 1 hp Craftsman ('70's vintage) nor my 7.5hp/80 gal two stage Husky. Both seem airtight. The little one sits for months between uses with 100 psi in it.
Charles
Stanger
Alton, IL
I have a Kobalt 60 gallon. It doesn't leak down at all. It isn't uncommon for it to go unused for months. When I turn it on the pressure is right where I left it and the compressor doesn't kick in.
MarkH
Kansas
The more pipe, filter, couplers, etc usually the greater leak down. The use of soldered copper has usually helped me. Less screw joints to leak. Then I go after it checking the filters as well as the remaining screw joints. Last one is down to about 5 lbs a day.
If I close the valve at the tank, it stays up. What I find helpful is having a few other turn off valves at other points in the system. I am able to turn part of the system off and check it section by section for leaks. May be able to get it even better over time.
The few people I know who are not having an air loss and it was the same for us until we started feeding distribution systems have the tank that goes right to a coupler. When we started adding especially filters the slow leaks started. Good filters took us down to about 1-2 lbs an hour more work took us down the rest of the way.
On setting up a distribution system, I have a rule of thumb. Expect to spend as much on pipe, filters, regulators, lubricators, solder, etc as I do on the compressor.
The last system had parts from around the world. 3 of the 4 from China were the biggest culprits and leaked and could not be fixed. Mexico was 0 for 4, USA was 0 for 50, UK was 0 for 5, Italy was 0 for 10, and Taiwan was 0 for 5 for defectives.
wrenchr
Disconnect the air hose when not in use!!! That is the only way mine leaks.
rickairmedic
louisville ,Ky
I have a 5 HP Us General 60 gallon no leaks here I do have a ball valve on it but its after some black iron and a filter dryer.
Rick
Stanger
Alton, IL
My compressor is set up so that it goes through a ball valve first before it hits the filters. That way I don't get any leaks when the ball valve is off.
MarkH
Kansas
Actually it may leak, but it is past the ball valve and does not drain the compressor down so the air loss is measured in tenths of gallons usually.
