sevensandeights
When the utility trench for my house to my barn was dug I wasn't there and the excavator put it in a very inconvenient spot that held up construction of the barn. I had to to hurry and run all my utilities and ended making a dumb mistake. I burried an extra piece of 1" conduit to use to run various wires in the future. Instead of leaving it empty I put direct burial coaxial cable and direct burial 6 pair 22g telephone wire. I am not sure what my reasons were for putting direct burial stuff in conduit but it's done now.
The conduit run goes through my basement wall and makes a 90 degree bend down to the trench and then another 90 degree at the bottom of the trench. Then, it's about 70' in a straigh line to the barn where it takes a 90 degree bend upwards and then through the foundation and then a 90 degree bend up to through the floor.
I now need to run cat 5 data cable and want to use the conduit. I tugged on the phone line and it pulled out about 6 inches and then got really tight. My plan was to attach a 1/4" 300# rated pull string to the house end of the cable and phone line and pull them both out and the string in. I would then pull cable, standard phone line, and cat 5 data through with the pull string. How hard can I pull on the wires to get them out of the conduit without doing damage to other things (conduit or foundation)?
I have a Jeep with a 8,000# winch and a ****** block (pulley) that I could hang from a rafter but am concerned that something bad will happen with this set-up!
Suggestion or advice greatly appreciated since the internet company is coming at 2PM monday to install the cat 5 cable.
