How much heat are Nylocs good for?
IntrstlarOvrdrve
Chattanooga, TN
I bought some stainless brake line tubing clips that came with stainless M5-.8 bolts and matching stainless Nyloc nuts. The clips mount on the frame, but my only concern is that I am running the exhaust tubing on my truck through the frame and the clips will be about 3.5" away from the pipe. It's not a high strength application but I wasn't sure how much heat the nut could take? The truck will be seeing a fair share of vibration so I don't really want the brake lines working themselves loose when I'm out on the trail.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I don't think the heat from the exhaust will affect the nuts unless you are running constant red hot pipes. Nylon can take some heat. You have to take a torch to a universal joint to get the nylon lock out of it. Now if you were right up against the exhaust, or using nylon lock nuts on a muffler clamp, then that would be different. At 3 1/2" away, you will have an air barrier between the pipes and the nut. And if driving, the nut would in no way get as hot as the pipe.
I
IntrstlarOvrdrve
Chattanooga, TN
Thanks! I would think that it stays under 250 degrees even being that close to the pipe. Guess I'll find out!
I would replace them with something else but none of the local hardware stores carry metric hardware in stainless and I don't want to order 100 of something else just to use four. :p
Of course I guess I could just replace the bolts with standard equivalents if it comes to it.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Depending on what the application is, you could always make a locking situation by throwing thread interference into the equation. Just like a crimp style nut, you can deform the threads on a stud and create thread interference, or if you have a way, deform the threads of the nut. Chances are the Nyloc will do what you need though.
As far as reusing a Nyloc nut like I read about, chances are if heat is involved, you may not be able to reuse one as the heat would thermal form the threads after a certain period of time. :dunno:
LumpyMusic
Phoenix Arizona USA
...I would replace them with something else but none of the local hardware stores carry metric hardware in stainless and I don't want to order 100 of something else just to use four. :p
If you have a bolt and nut supply place nearby (not Fastenal) you might just find that a box of 100 nuts from them is cheaper than 4 singles from Ace Hardware or similar. For me, it's ALWAYS worthwhile to drive across town to Copper State Bolt and Nut in Phoenix than it is to drive 1 mile to "Ace is the Place with the Expensive Hardware, Man".
Sgt Lumpy
MikeF2316
Thornhill, ON
I didn't know that a Nyloc could be reused :dunno: Learn something everyday. :thumbup: In our business, we weren't allowed to reuse them.
+1 I thought all lock nuts were supposed to be used once only. Of course I may not have always followed that advice, not that I was doing anything wrong as it turns out.
OP, just make sure none of yours have the nylon jammed in the wrong side of the nut, like this:
