wantmo
I have a 35 x 28 (minus a couple of corners) attached 3 car garage. I had an HVAC contractor come in to quote adding heat, and he quoted both a 24k BTU natural gas and an 11k electric heater as two options. I was expecting at least 40k BTU, and online calculators are all over the map. The contractor was a bit concerned with natural gas supply as the gas line enters the house on the opposite corner so is a long line - so he said electric might be better.
Construction: Garage is 14' tall. Approximately 35' of wall is common with the house, and there is a bedroom above part of the garage. Walls are brick, with a 1" rigid fiber board insulation and 2x4 construction. I plan to insulate walls (hopefully spray foam), ceiling (on section without the room above (unknown current insulation) and drywall. Garage doors face north and are being replaced with insulated ones, and there are man doors to the house and back yard and a set of windows.
Goals: Keep garage above freezing in the winter, and be able to bring the temp into the 60's a very few days a month when I am going to work for a more extended time. I can handle a longer recovery time.
Climate: Front Range CO. Winter days are moderate, with a larger swing from day to night temps. We do get a few days every winter where the temperatures are below 0 F, as well as several warm days. I've attached a graph of the garage temps this year from mid-Feb to mid-Apr against the daily high and low. Unfortunately I missed the typically colder end of Dec through start of Feb.
My inclination is that I would be happiest with the natural gas solution, but not sure if it is enough BTU's. I'd also appreciate any comments on the location noted.
