How much more useful is a mill with DRO
HoosierBuddy
Southern Indiana
Hey guys,
Let's cut to the chase.
I have an old U.S. Burke Millrite 8X30 Knee Mill. I use it for hobbyist type stuff plus make a few parts to sell when I can (automotive bling pieces). The mill runs an average of 20 hours a month.
I think I want to drop some $ and put a DRO on it.
But then there's another part of me that thinks that dropping a grand or so adding a DRO to a 40 year old milling machine that might only be worth $1500 or so is stupid.
What do you guys think?
Phil
rsanter
visalia ca
It will not make the machine more useful. It will make things easier for you when you use it.
You can do it the old school way by just reading the dials and for circles you can do the math to figure out where to be for the desired pattern
Don't look at it like dompinf money into that mill. The DRO is a separate piece to me and if you buy another mill you have the option to swap the DRO over to the other machine
Bob
E.Marquez
Kempner Texas
Yes it's worth it.... Just did this myself for a Mill and lathe.
Can the same milling operations be done without a DRO as with? Yes, of course.
Can they be done with repeatability, accuracy and without the inevitable human error NO.
Don't think of it as an investment, it's not, you will not see a $ for $ or more return on what you spend.
It is simply another tool to make a job better, faster, more enjoyable and part of the tinkering mindset most of us have.
Have a look at the DRO STORE http://www.thedrostore.com/
Yes it's off shore suppliers. No you'll not find a Tech Rep that will come to your house, install it, service it, teach a class on using it..
But the products they sell work as advertised.....at the end of the day.. I assume that is what your after..
Possum
KS
The DRO will really improve the ease of use of the machine as well as provide way more accurate positioning of the machine. Especially over the full travel on an old machine with worn lead screws.
Cryptic1911
Willimantic, CT
You don't need to spend a grand on a DRO.. Look on ebay, you can get some decent 3 axis ones for under $500 with glass scales
383 240z
Findley Twp. Allegheny Co.
Buy the DRO. Dont look back. I used a mill last week with one. I used my mill last night. I hate reading those dials now. I'm moving it up to the head of my list on the must purchase. I even put it above my rotary table. Here is where I'm getting mine. http://www.cdcotools.com/ part number is 30002 Keith
justanengineer
Motor City
Not to be unkind, but it all depends on YOU. We cannot tell you what your ability to work with dials is compared to working off the DRO, nor can we tell you if its worth the $$$ to increase productivity some small amount. We also cant tell you whether or not the small amount of travel lost on a small mill from installing DROs is worth it or not. Personally, to me on that machine it wouldnt be, I'd rather sell it and buy a slightly larger machine like a Bport that already has a more capable professional DRO for the same or less $$$ (aka find a deal).
A close family friend has a shop full of early machine tools with which he makes his living. He's an older guy now, so everything has a big screen DRO and feeds on all possible axes....even his big 19-0-something vertical mill (Kempsmith IIRC)
zkling
DRO's can really shine on machines with quite a bit of backlash, thus improving the useful life of a machine tool.
Are they handy, sure. Are they a necessity, not really. Kinda like an impact wrench vs breaker bar. Will a breaker bar get it done, of course. Will an impact be faster, and easier, of course.
DRO's can be real handy when manufacturing new parts from bar stock. Or if you have complex parts that require repeated transversing of the table (compounded backlash). Some of the higher end DRO's have handy features like pocket, bolt hole and off set parameters.
If you want something on the cheap you could try mounting a semi cheap set of digital calipers to your table. Especially since your travel range is not that long. I did this to my clausing 8520 and it makes it really nice. I picked up two 8" Mitutoyo digital calipers off of ebay for $100 total. Made up some mounts to the table. Work good for the small stuff on the 8520.
Steevo
43.49600, -112.04300
It is sooooo much easier to do repetitive operations with a DRO to guide start/stop points.
My first mill was all manual, and my second has DRO.
Next will have CNC.
Or maybe I'll just buy a 3D printer and print stuff . . .
helterskelter
I wouldn't want to use a mill without a DRO (unless I was just hacking sh*t up). The 500$ will pay for itself in time and frustration.
HAP
NE North Carolina
Makes milling operations fun and repeatable. Makes even the cheapest machine look cool(er). Plus if you accidentaly bumped your dials you will know it...
HAP
Lots of ways to get to the DRO beside a high end kit. Do some research. and yes it's worth it, unless you dump silly $$ into the upgrade.
larry_g
oregon
The subject line made me think, When did DRO's hit the market? This link says 1972. So we fought wars and put men in the air and men in space without DRO's. Your machine will not be more useful, but a lot easier to use. One other advantage to the DRO is with the push of a button you can switch to metric units.
lg
no neat sig line
oldgoat
Wichita Kansas
If you are doing much at all DRO is almost a must. Sure you can try to set things up to just use one side of the backlash, but it isn't always possible. It also will allow to do things like hole patterns and be faster and more accurate. Unless you put indicators all over the place you won't know if you have moved into a worn area and it has moved. Yes we put men into space but they also had some great machines down in Oak Ridge that were already in climate control buildings and NC machines. Heck in the mid 60's we had NC machines running, but they were still using trig tables and slide rules.
H
HoosierBuddy
Southern Indiana
Really good information guys.
I actually am glad that my mill came without DRO. I think it taught me a lot. The above posters are right. You really have to work in one direction to eliminate backlash. Another thing I do A LOT is set my stops and work between them for repetative work.
I'm giong to look at that sumatech site. That stuff REALLY interests me.
I'm building a robot with my kids right now and taking an online Python class to update my programming skills, hoping that translates to programming microcontrollers and such. A DIY DRO kit that was cheap would be awesome. Of course, the transducers (scales) are going to be a big part of the expense....
Phil
