How much stone?
bmwpower
How do you figure out how much stone is needed for a certain area?
I'm talking 3/4" crushed...
DUG3x3
If you are trying to figure out how many "yards" for a certain area.
You would multiply the length x width x depth, divided by 27 = the yards.
example: 24' x 24' x.5 =288 / 288 divided by 27 = 10.6 yards total
So 24' x 24' , 6inches thick will use 10.6 yards.
There is also factors for compaction , and many other ways to calculate the yardage needed , but hopefully that helps.
doug
toms73novass
grand island, ny
once you have the number of yards you need call up a stone distributor and they can ball park the number of tons you will need. They charge by the ton, if I rember correctly I needed 11 yards and had 20 tons of #1 chrusher run delivered.... but i'm loosing my mind
snorvet
Northern Illinois
as stated above,
take length x width x thickness in feet and divide by 27 to get cubic yards. Figure 3900 pounds per yard for compacted stone. (non-compacted would be quite a bit less). So if you need a number for a compacted thickness, take 3900 times cubic yards, divide by 2000 (lbs per ton) and you'll get the tonnage. Most places sell by tonnage.
Old Moparz
Newburgh, NY 12550
Once you get the total for cubic yards, you can multiply that number by 1.5 to 1.8 to get the tons. (The moisture & fines in the stone will be a variable.)
24'x 24'x .5' = 288 cf/27 = 10.6 cy x 1.8 = 19 tons
