drummerdimitri
I'd like to get a pneumatic impact wrench for general metal fabrication and I'm not quite sure how much torque I would need for the majority of fastening applications.
I will only need to tighten down M12 bolts into tapped threads no deeper than 20 mm and at most M20 bolts fastened to nuts (very rarely if ever).
The bolt grades that will be used will vary from 4.8 to 8.8 and will be coarse grain.
Knowing this information, what would be the ideal max torque number for my application? I have no prior experience with pneumatic wrenches and hope the fastening torque can be adjusted somehow on either the tool itself or at least by lowering the input pressure (not ideal as that would also reduce the speed and BPM of the wrench).
Would this be an ideal one?
https://www.intlairtool.com/ingerso...mpact-wrench-15-000-rpm-332-ft-lb-max-torque/
