How much would you give?
spent21
Franklin, Tn
So I came across this guy. How much would you give? 2nd owner says he used it twice and put it in storage. Everything is tight. The pulleys don't even have the paint worn off of them.
It is a 16.5" free standing press with a 3/4 120v motor.
It needs a good cleaning, but otherwise, everything is square, no runout and solid...
I came across this ad that is asking $650.
http://www.johngweber.com/jgw/boring/b1096.htm
and I saw another local for $450:
http://nashville.craigslist.org/tls/4056518936.html
7th Kahuna
Los Angeles, CA
I'm with the $150 max crew. Older, good quality drill presses come up around here regularly for less than that. I paid $50 for mine.
plier_able
I'm also with the $150 crew. These things come up fairly often. If it was in real good condition and I REALLY wanted it, maybe a bit more - but I am not an expert on this sort of thing.
rsanter
visalia ca
I agree with $150. Because it has so little use I would go to $200 tops if I really needed it, wanted it, or couldn't find anything else
Bob
