How often are hex bit sockets over 10mm-3/8 used
toolaholic
PA
BiggityBen
i use 1/2 and 3/8 all the time for electrical related work. output lugs on generators mostly.
T
toolaholic
PA
I have up to 10mm in a Williams kit. Found a gearwrench 12mm and a craftsman 14mm impact. So I’m guessing that’s big enough. 17,19 and 22 I could acquire gradually.
setfocus
rust belt
Newer Grand Cherokee caliper slide pin bolts are 11mm and that's all I can think of for domestic cars. Some VW/Audi axle to hub bolts are a bigger allen head, probably some other german ****
brollona
floating arround
I'm currently maintaining MAN HIMSEN diesel generators and I have couple plugs on casings for oil filters that require larger hex keys. I don't remember now is it 14 or higher. Also on, these engines have some plugs that require custom 3/4 sockets which are something like 40mm. Didn't used them yet.
I must admit that I like working with bigger stuff.
vssjim
McLean Va.
11 12 14 17 popular if you work on modern cars that are eurotrash or 11mm is on FCA caliper pins.
Firebrick43
West central Indiana
Had lots of socket heads 3/4+ in the machine shop, especially old equipment.
+1, in machine tools, the use of hex headed bolts is uncommon, almost everything is allen headed bolts. Some of our larger machines have 40K lbs fixtures and they are all bolted down to the x axis or rotary table with 3/4 or 7/8 allen headed bolts. Alot of mid size is 14mm, 17mm, or 1/2"
For ever i wondered why manufactures had 7mm allen socket in a set as I had never used one. Well now I have a machine that I service regular that exercises my 7mm quite frequently.
Squankum
Southeast
17mm = VW 020 transaxle drain, fill plugs
14mm = Mercedes diff drain, fill plugs
(Mind you, some might say my cars are old.)
gatlibs
N/A
Drain and fill plugs for transmission and transfer cases on Keeps (Cherokees-xj and wranglers-tj).
bwringer
Indianapolis
12, 14, 17, 19, and 22 are found on motorcycle axles.
The impact hex set from Harbor Freight is very nice quality, but only goes up to 19mm. For 22, I make do with a 7/8" coupling nut, but at some point I suppose I should buy a proper bit.
Dave455
Sussex, England
Like a lot of these things, it depends what you do.
A lot of the bigger sizes are used on machine tools, both inch and metric, depending on the machine. If I’m working away from base, the hex bit sockets are probably the most portable tools to deal with these.
Automotive? I’ve certainly used 14 and 17. Maybe not as often as the smaller sizes, but I’ve certainly needed them.
In the U.K. a lot of safes are secured to concrete with massive cap screws, and I’ve needed sizes up to 5/8 to remove and re-install these. You pretty much need a ratchet and hex bit, unless you like a lot of winding - 4 inch screw, or longer, are common!
InjectorService
Canada
I'd get the larger of the sets. For me its one of those things I use once in a blue moon, but man am I happy when I do have them!
1foxracing
Tuscarawas Co, Ohio
Just buy one of these, stick it in the axle and you can use a socket or wrench on the opposite end.
rstQNzZFKle0qpzjoDUvlTxtuIB2Kbzf_8ATeGk0QDu-QLJsi-ZzwfP6Sd2BEMb1MgA2wLEgTqJ3BN2yhqADL78E5lJEFb0jutHSzu2g15LTCW-Sr60Qn7_aKswsIXapoGof50AXF4IwcPjSLrZUvnuGu6Bh9Z76_xKXq-kQEf29cYtcFa0PIVg9ZeHvODgt70WlBiABwtoZ3J7EKu9e7CpO9Q4w7mUMfkCgOeoLYBBZjkWaaxSBC9xYb6YSTSt6wnixYQ0LVEEYjxsKbZatiucdFmwfGlaOEOFRPDAqI1N8HLj5bzU68vFSywEeSgcFs_hgfuQ9Efm_wFEmfvlRnGUBth_4boyDGOACBE2b7VQTpOhuy7RX6Ge126lKlF3-ELJWIFPwweM_3UEhlSFMuu_ooqkAqQjQAGCilZe6zf6X6GVKUezYw41AUIRCTXs_3OgXyeAX8j05BTADFb9LEapmFvrVd5IUp-8mP79tdV9c0Wm3vA5mEkYAoqKalhTnj4IspZvVgzj1t_WSWC9QgkR_y7aUsrOcyfX2tQfbin_KAAcs1-43S-XBsGUvkVnbrc1r7sAVooO0hOLQKsRtYT3sHgGynGfQmsYe0iwGqqmF8rB2c5gcm7v-RxsBHp5m7C8Uct7vpbfrF4ZHp5JBt3PQKOL-plKg7K_pk_gRLgm3rMoG_7gIKkbhP0cfl1n86AQztMIISf-iftzEizSi0QDAd6wwFF7x4tDBdGvgnvy8XVQzey5R69yq=w602-h903-no
DFB
Southern VT/Western Mass
Ya that what we use at motorcycle shop for too...those odd jobs we get :beer:
OP I have mostly standard hex all the way up to 3/4" in my own tool box
Cant say I use them that often and 3/8" and under is much more common but they are there if and when I need them.
Good price on what ones you linked though. I do like that stubby set.
I have longer tip in impact style along with the older style chrome socket ones but none go that big
bonneyman
Desert SW
An old guy at the hardware store told me - for large/odd size allen fasteners - he recommends getting grade 8 bolts in the hex size you need and locking two nuts onto it. You then have a place to put your wrench/socket/impact.
Haven't tried it yet but he was one smart man and I trust him.
Leaflessshadetree
Don't ask.
I've occasionally used some of the large size. I don't recall where.
I have also double nutted a bolt. Used the bolt head in the hex socket and a wrench on one of the nuts to turn it.
