How often do you change the oil in your compressor
CompressorPros.com
SC
I've been in the compressor business for a long time and from time to time I would get a call from someone who has had a compressor for years and just is seeing what kind of oil it takes.
So, I'm just wondering how often you guys change the oil in your compressor?
stikman56
Rarely. I changed it in the 80 gallon I bought because it had a few hours on it and hadn't been changed yet. Never changed it in the 20 gallon CH that I had and used quite a bit for about 12 years, and it was my neighbors for many years before that. Still was working great and passing no oil (that could be seen anyway),when I sold it. Plan to change it maybe every 6 or 7 years in the 80 gallon I have now. I gotta wonder, how often is it really needed?
C
CompressorPros.com
SC
I think it really depends on the usage. If it is nasty dirty, it's time to change it. A lot of manufacturer's will say 3 months or 300 hours, but that is probably excessive for most.
stikman56
Yeah, it was still very clean looking in the CH compressor when I sold it after all those years, so I figured, why bother with it. I changed it in the almost new one I bought to get the break in metals out. Only reason I did. This 80 gallon Husky compressor did have a little darkness to it when I changed it though.
rockfordmarv
Never. I really don't have many hours on mine, but I will probably change it out before the snow flies. I should probably open the water drain on mine more often.
Thumper68
Duluth MN
I change mine around the two year mark, I did add a longer ****** to make the changes easier at some point.
RacerRick
Durham Region, Ontario, Canada
I change the oil in my old 5hp CH every two years since it is cheap. I also drain the compressor when I get to the shop and when I leave. Its amazing how much water can condense in the tank on a humid day.
Carla
MEMBER EMERITUS
Well, this may be 'just superstition', to be sure, but I tell people to change compressor oil every three to six months, depending on the level of service the compressor is used for.
I say 'superstition' as I am woefully ignorant of oil chemistry, and really have a very limited understanding of the ways in which oil may degrade over time, heating/cooling cycles, etc.
Given such ignorance, I think it easiest to think of oil changes as 'insurance', on the theory that oil is much cheaper than bearings, and the value of the working time needed to pull a pump down for overhaul.
This much I can say, from first-hand observation. I've pulled down some number of the old recips which had the heads carboned-up nearly solid, presumably from using the wrong oil, and seldom if ever changing oil. Some of these were marginally cost-effective to rebuild, given the amount of working time needed to literally drill and chisel out the hard carbon formation in the discharge porting.
(I particularly remember one 10hp Quincy which had been used in an automotive shop for several decades, with the suction side piped outside the building, but without a filter. It had bad ring/bore wear from....presumably....fine 'road dust', which would be ultra-fine silica particulates, a rather nasty abrasive, so, eventually, a lot of oil got past its rings. It had, apparently, been run on some sort of detergent automotive engine oil, and still ran smoothly, but didn't deliver very much air....the head/valve porting having become nearly a solid block of hard carbon.)
Allegedly, the stuff sold by the major oil companies as 'compressor oil' contains some additive to reduce such tendency to carbon formation.....I say 'allegedly' as I've no knowledge of the oil chemistry involved.....but, if it works.....well, its 'cheap at the price' if it keeps the compressors doing their work for a good term of service.
cheers
Carla
Parrothead
Earth
Mine's 3 years old, never changed it yet. I haven't put it to hard use, but I did put synthetic in it.
sberry
Brethren, Michigan
The humidity in my building is so so,,, but mine runs several cycles a day, a 3 hp on 200 gallons of tank and it gets warmed up so I did a 10 year a while back when I had it pulled out for other work and put Amsoil or Royal Purple back in it.
I really doubt it would have made any difference but it holds a quart and it was convenient. I would say likely in the 1000 hr + range.
Jason280
I do mine once a year, regardless of the hours (mine isn't used that much). Like it was posted above, it's cheap insurance against an expensive replacement.
dlcwent
Member Emeritus
coastal maine
Every 6 months and a new air filter too. Don't want to think about buying a new one. They're too expensive.
But mine runs 6-15 times a day, 5 days a week.
22george
SW Ohio
When l bought my Eaton compressor l asked the tech rep. He said change the break in oil after 30 hours and then every 300 hours after that. I put an hour meter on the compressor. He said to use non-detergent oil.
Ign
Butte Peak ND
I've changed mine once in 11 years. 80gal Craftsman. Honestly I don't plan to ever do it again.........or maybe I'll get a wild hair next spring.
Squankum
Southeast
Every two years. Cheap and easy. I bought my Kobalt compressor used a few years ago, wasn't sure if it was one year old or three or what had really happened to it before I got it. It seemed almost like new at the time.
So I changed the oil about a year after I got it, installed a drain valve in the plug hole to make it easier next time, now two years have past, just did it again. Oil still looked golden and clean. Metal flakes, though. Hmph. Well, I'm glad they're out of there...
theknurl
SoCal
my compressor tank is dated 1946....painted the same color as the pump
I got in '75 or '76
the oil in the sight glass is nice and clean
so that's at least 38 years WITHOUT a change
and its been on 24/7 since I got it :thumbup::thumbup:
:lol_hitti
wild cowboy
Birmingham
I rarely change it, no more than once/year, but this is why I use synthetic oil (Pennzoil Ultra 0W-30) and it has the added bonus of my compressor starting on the mornings when it is negative temperatures and other compressors lock up due to the oil being too thick at that level of cold!
chris142
apple valley,ca
the one at work gets new oil in September then again the following year around April. so 2x a year.the one i have at home once a year but im going to start extending that since its such a disaster to change that one.
chipper
Williamsburg, va
Once a year...it takes me 5 minutes. It seems like I only use it now(since cordless)for pumping tires and blowing up kid toys/floats
wagzilla
Arizona
every three to four months, oil is cheap compressors are not, when I see the color change to a little bit darker, it only takes 5 to 10 minutes my compressor is 25 years old and I have done nothing else to it, well wipe it down.
James
1953mercury
Steamboat Springs CO
The Quincy which hangs on the wall of my Dads shop has been there for over 40 yrs and has never been changed. Still works fine and gets used regularly. I change my 5hp 80 gal. every 5-6 years and it gets used hard, and has been in service for over 20 yrs. Compressors don't see anywhere near the stress an internal combustion engine does. Mike
BUDSVTX
Destrehan La.
I use my compressor 4 or 5 times a month, bead blasting, air up tires. I used to change the oil once a year. I have now switched over to AMSOL for 4 years, the oil is clear and easy to see a color change. I have about 100 hours on AMSOL and oil looks great.
I try and drain my 80 gallon tank at least once a month. No oil at all.
BUD
Plombob
Tennessee
I have an IR 2000 I bought new back in the 80s that sees occasional use. I just changed the oil for the second time and the old oil was the same color as the new oil.
I am religious about blowing the water out of the petcock during shutdown. I worked at a shop where the boss only drained the compressor when water came out of the air hose.
CompressorPros: what is your recommendation?
