How often do you use 1/2" sockets/ratchets?
liliysdad
A little bit more: I would say the exact same thing about 1/4” drive. Using craftsman for years, I never touched 1/4” drive. The sockets were loose fitting and the short ratchets reversed under load.
Now with Snap On 1/4” and a bigger selection of longer 1/4” ratchets, I find myself pushing that drive more and more. I will readily attack a 13mm bolt with 1/4” drive. I’ve got ratchets long enough for that to be comfortable and I’m learning to trust the drive.
Physics wise, smaller drives, lighter ratchets are faster and typically have lower back drag. So if you can engineer strength into your smaller drives, that becomes an advantage mechanics will learn to exploit.
Absolutely this.....long handled slim head 1/4 ratchets are the most used ratchets in my box.
bobg03
conway sc
Most likely < 1% on 1/2" stuff, I got rid of a lot of 1/2" except for an older breaker bar, long handled ratchet, 3 extensions and a rail of 12 SAE sockets and another rail with 12 MM sockets, all older Craftsman USA tools. I'll probably never use them again but they take up minimal room in a lower drawer, and if ever needed they are here.
85% 1/4
14% 3/8
1% 1/2
Robinson1
Kentucky
All my impact sockets are 1/2” drive. But with hand tools I usually switch to 1/2” drive when the socket size goes over 19mm. Of course they’re exceptions.
I’ve found a really comprehensive set of 1/2” drive sockets say from 10mm thru 32mm and 3/8” thru 1-1/4” can pretty much replace 3/8” drive completely. You can take a basic 1/4” drive set and a good comprehensive 1/2” drive set and handle about any job
f121
UK
It really depends on the job and the vehicle. My 1/2” gets used a lot on suspension and brakes, sometimes 3/8” simply isn’t strong enough:
I probably use about 50% 3/8, 20% 1/4, 30% 1/2. I do like having a high torque 1/2” impact because there’s no question, it’s coming undone, or snapping.
finn
The UP, God's country
If you were really determined to minimize, you could cut your tool kit down to a single small entry level tool box, couple jack stands, and a small floor jack, just like I had as a 17 YO Private in the Army...and break tools and parts, bust your knuckles, and be forced to rush to the store and pay top dollar when you find out you need a tool you don't (or no longer) have. Just like I when I was young, starting out, and building up my tool set. Been there, done that, don't see a point in going through it again. Don't need the pennies on the dollar used tools bring, can certainly spare the small amount of space they take up.
Tools, are why we have garages. Then when we fill up the garage with tools...build another one so we can actually work on something. Rinse and repeat as needed.
Most of the populace could get by with a crescent wrench, vice grips, a claw hammer, and a couple of screwdriver.
Actually, probably less.
Wrench97
Southeastern Pa
I used a 36" long 3/4 drive ratchet today to remove a Toyota cartridge filter.
At least once a week I wonder what in the heck the last guy thought he was installing when trying to remove a filter...................
Had a 4.3l GMC 4x4 towed in yesterday the guy couldn't get the filter off at home in his driveway and crushed/tore the shell, at least all the oil had already run out of it when I got under there.
AEAdam
SE PA
It has been my experience that people who Toyotas do so, not because they love driving, but because they (mistakenly) believe Toyota never need maintenance.
The diehards who let the dealers service them, often get suckered because the dealers know the Toyota drivers know NOTHING about cars. Their customers literally chose Toyota because they hate cars. So they end up with $500 tune up charges.
Consequenly, every time I’ve had the opportunity to work on a Toyota, it’s been a **** show. And the drivers seem continuously pleased with their cars. “Well it smokes, but what do you expect, it’s a car!”
Their slogan should be: Toyota: THE car if you HATE to drive.
2ndGearRubber
Pittsburgh
OMG!!!!
Who screwed the pooch on that before you got it ??????
Begs the question: were you working on a Toyota or was it the ship that brought it over?
Issue is tooling IMO. Most of the filter cap tools have a 24 or 27mm on them, with a 3/8 square inner drive. That usually fails, so people use 1/2 drive with the big sockets, and "snug 'em up" instead of the 25nm/18.5ftlb spec.
Pretty sure the guy who reinstalled didn't use a torque wrench either. IDK, I got my laugh with the 3/4 and went back to working.
cannuck
Rural SK
Issue is tooling IMO. Most of the filter cap tools have a 24 or 27mm on them, with a 3/8 square inner driver. That usually fails, so people use 1/2 drive with the big sockets, and "snug 'em up" instead of the 25nm/18.5ftlb spec.
I have encountered a few filters that are spec'd to be torqued on, but I have yet to encounter one that didn't seal properly with bare hands. I usually go from first seating plus 1/2 to 3/4 turn based on how it feels. I am absolutely disgusted when I have to work on something someone else assembled (filters, wheels, oil drain plug, etc.)
2ndGearRubber
Pittsburgh
Normally I just crank on filters with my hand. Spin on filters. These toyotas use a cartridge filter with a replaceable element. Literally has the torque spec printed on the housing, 25nm. I torque all drain plugs and filter housings for CYA. Nobody ever asks if I torque the timing chain rails or control arm bolts for some reason.
kbeefy
Harington, Eastern Washington
I'm the hand tight filter guy also. Clean the mating surface, lube the gasket, snug it up. Gotta use a tool on the cartridges due to drag torque, my hands aren't strong enough to seat the o-rings.
I have had a few of those... The toyota cartridge housing seems like a good Idea but people can screw up anything!
I've ruined a couple tools trying to break those loose. Finally found a good socket that engages multiple teeth on those things.
kbeefy
I still use my 1/2 stuff quite a bit. I do have an 18" 3/8 ratchet that replaces my 1/2 in many cases.
My 3/8 impact can remove a lug nut, but my 1/2 makes it look so much easier.
I towed 2000# with my subaru outback once, and 4000# with my Tacoma once.
They did it, and everything was fine. But when I do the same thing with my F350 it makes me wonder why I ever bothered.
dnschmidt
Phoenix, AZ
If the F350 has a 6.0 in it you'll be using your 1/2" tools a lot. Just finished rebuilding one of these dogs even though it has the $10,000 bulletproof kit on it. They don't run very well with a hole in one of the pistons.
DGersic
DeKalb, IL
The cartridge housing on my Camry was stuck to the point that the housing tool sheared off the drive ridges on the housing. That was fun…
finn
Subaru’s aren’t far behind.
kbeefy
The F350 should have a 7.3L in it. But I'm not sure if Ford offered different size engines.
I just looking at the filter and oil capacity specs for that yesterday (it needs 8quarts).
Thats the lowly gasoline engine (a good engine as far as I know) that the peasants drive.
My 7.3 takes 15 qts of oil. I have a 55g drum I've been working thru.
Hohn
Diesel Central, Indiana
I have yet to see an oil filter for which "as tight as possible by hand" isn't sufficient.
Jr5
I have my dads vintage SK 1/2” breaker bar that I keep next to the seat of my truck…. In case lol.
A
AJHD
I mean it sounds like you've pretty much made up your mind that you don't need 1/2", in which case I don't know why you'd hang onto it.
I personally try and get rid of everything that I don't need, because otherwise it's just taking up space and getting in my way. For better or worse I've found my 1/2" important enough to keep around, part of that may be just desire to have it, but it is pretty low maintenance and I've got the room.
I'm more or less the same way. I'm not a true minimalist by definition, but I own very little (on purpose) and generally don't have emotional attachments to material objects. In fact, too much stuff gives me anxiety and makes me feel "trapped".
Anyway... I've decided to keep the 1/2" stuff for now. I'll revisit the topic in the future and see how/if their use has changed.
2ndGearRubber
Pittsburgh
How didn’t you destroy the housing on that?
V6, aluminum housing.
Doesn't work on cartridge filters. I've seen enough leaks from lube techs and DIY. 18.5ftlb/25nm. Just torque it.
New guys always wonder why I use torque wrenches, nobody else does, grandpappy never used a torque wrench. IMO it's so little time and effort involved even to torque an entire timing cover I need to ask why wouldn't I use a torque wrench? I certainly can tighten things by feel, and have no issue doing so when needed.
CGarage
United States/Switzerland
Thank you for being professional.
More in the auto service field need to behave like you.
2ndGearRubber
Pittsburgh
IMO it's literally easier to just use a torque wrench.
I will "snug it up" when required, but more often than not mission critical bolts can easily be torqued. And there's a time and a place you certainly don't need a wrench, like putting up an under tray.
Once you've helicoiled as many bolts as I have, you learn a few things! I once bought a $500 quad as a toy. Im.pretty sure I helicoiled every hole in that case! LOL
65k10
somewhere
Another person who deals with ag equipment on a regular basis, so 1/2 drive is used often enough. I can't say I use 1/2 much on automobiles beyond lug nuts, but if it is anything all that involved, I usually have an actual mechanic fix it. That said when I do work on a vehicle, I'm suddenly much more appreciative of the long 3/8 and 1/4 flex head ratchets people praise on here. On farm equipment the long 1/2 ratchets get a lot of use while in 3/8 and 1/4 a standard handle ratchet is usually good enough.
KnurledNut
n/a
I do 10/20/30 lbf. on those Toyotas...plug/filter housing/drain bolt. Easy to remember.
Factory filters only. I also grease the O-ring and where the housing seats. And new OEM blue drain washers every time.
I learned a long time ago not to use those removal tools with tabs that engage the wings. They can destroy the housing.
DGersic
DeKalb, IL
I swapped to a Fumoto valve on the drain, so that’s no longer an issue. Open, close, done.
If you’re not using the fancy cup wrench to engage the wings, what are you using?
