pendragon1998
I had a starter with a broken off non-hardened screw in about 1" of cast iron. The screw hole was open on te bottom, so I decides to drill it out from the bottom, then thread it for a larger screw. I selected a new #7 Chicago-Latrobe HSS black oxide 118 degree bit and an electric hand drill (don't own a drill press). I used a drilling and tapping lube.
The drill worked fairly easily through the work, with me taking my time, but I had it slightly angled, so the bit ended up starting to exit about half a diameter over towards the side of the starter. Basically part of the bit circumference was free and a crescent shaped portion was still going through the starter body. The bit jammed and the drill chuck spun around the shank. I pulled it out, tightened the chuck, lubed the hole, and started again. This time, it jammed and the bit shattered, cracking in half and shooting a piece into my stomach, cutting me a little.
It was my fault, but I would like to be educated on how to do better next time.
