How should i wire these 2 Compressors?
koster88
Hey Guys.. Trying to figure this out...
I have 1 compressor that i've had for a while. It runs on 230 3 phase. I plan to put a 2nd compressor right next to it. Both Compressors use the same Breaker/Wire size. 1 will be used only for my Backup. The problem is I dont have any more spots in my pannel to put more breakers. So I need some type of "switch" to be able to go from 1 compressor to the other. I would mount this close to the 2 compressors. How can I make this work?
tadder52
Northern MN
Either two switches that you know you can't run both compressors at the same time or look for a three way toggle switch -- comp A, off, comp B. I think you can find something like that.
Ad13
BC
A backup incase the first one breaks? Or a backup for extra air?
1Garageman
Columbus, Ohio
Could you put a subpanel in the shop so you have more power options for the air compressor and what ever you might add in the future?
K
koster88
Do you have three phase service in your shop?
What horsepower are the motors, and Full Load Current amps?
Charles
Yes I have 3 phase.
I have 1 Compressor now. Its a 5HP 3phase, and is wired correctly (using the last breaker in the shop that I have available). I am adding a second Compressor (not for extra Air, but as a backup in case the 1st compressor has any issues. I want to be able to just flip something, and switch from giving power from 1 of them to the other in case i need to service the 1st compressor.
That would be the cheapest. Or he could use a 3 pole double throw switch that would switch the feed wires but that will be a little pricey...
