I've done some digging (searching) around in here and still had a few questions...
I'm looking at installing some L Track in my truck bed for tie downs and to bolt a mount for a Hi Lift Jack. I'll likely use the stainless bolts they sell for the bed rails, as I can put washers and really clamp onto the sheetmetal. The WLL is 1666 lbs for just one of the clips that go into the L Track (common for strapping ATV's and motorcycles). I don't think I'll be using it for anything that heavy duty but you never know.
https://www.uscargocontrol.com/shop...irline-Straps-Hardware/L-Track-Tie-Down-Rails
The problem is between the cab and the bed there is no room for a wrench. So to save me the time of removing the bed and sliding it forward, I thought I'd use rivnuts. From what I can see, the area where I'd likely be drilling seems to have at least two layers of metal maybe a few millimeters thick.
If they are strong enough I'll likely use them in the floor of the bed as well, also to keep me from removing the bed. Although the metal seems thinner in these areas.
A 48" piece of L Track has 10 mounting holes.
What say you guys who have used these?
Also it seems the Astro tool seems to be the go to on Amazon for $60...
