How tight should I pull kitchen cabinets to dishwasher
branimal
The instructions say minimum clearance is 23 7/8". I made the gap 24". That's leaving me with a ~1/4" gap on each side. Should I pull the cabinets to the right of the dishwasher in a little tighter? Leaving 1/8" on each side of the dishwasher.
And is that black rubber flange supposed to sit behind the cabinet face frame?
Thanks
glentre
Gloucester, Virginia
The instructions say a MINIMUM opening of 23 7/8. You will be fine with a standard 24" opening which will give you an approximate 1/16" gap on each side, not 1/4". The actual gap depends on the true width of the dishwasher which will be slightly less than the recommended 23 7/8" opening.
Glen
larry4406
Northern Virginia
All of our new construction homes we set the dishwasher opening at 24” exactly.
Can’t help you on the black rubber piece. Read the manual?
yeldogt
24" it the normal spacing -- just split the difference on each side and make sure it all level and square -- the rubber should face the back so it does not stick out. The front of the case matches the cabinet face.
rlitman
Long Island
The cabinet spacing should be 24" exactly between the face frames. The rubber gasket takes up the extra space, and should sit flush with the front of the face frames, leaving no open gaps at the sides.
If you're doing a stone top, you have several dishwasher attachment methods. Many allow you to put screws into the sides of the face frames to avoid drilling the countertop. That works, but I prefer the top screw plates, as they're both better hidden and stronger. On my last install, I used one of these:
Before that, I drilled and tapped a 1/8" steel strip that I then painted and epoxied to my stone. The bracket is MUCH easier.
Toolfool
Tallahassee, FL
Convinced my countertop guys to install the epoxied strips as standard procedure. (y)
nadogail
Coronado, CA
If you follow the manufacturers instructions you will be covered if there is any question about why you did it the way you did.
If you deviate from the instructions, you are on your own when someone asks you "why?"
