Hollowellreid
- Joined
- Feb 7, 2011
- Messages
- 24
Here is my little 20x20 garage, I think it was built sometime around the 1940's or so.
Soil is really sandy around here so everything is in good condition. The floor is fairly flat and has no cracks, heaving, or other problems.
However, it looks as if the concrete was mixed way too wet and the excessive bleed water caused the top to pop/spall on a large majority of the floor.
As of now it seems to be pretty solid. No more flaking or wear that I can see.
Basically I use the garage just for storage of a car, a couple motorcycles and maybe do a little woodwork in there. No real mechanical work, welding, fab, etc going on in this garage. Just storage, the family has a large shop to use for in depth work.
It would be nice to have a smoother epoxy finish. Would look much nice and also be easier to clean. As of right now it is so rough that it is a pain to sweep/vacuum up the dirt.
In essence I need to find the best/most affordable way to fill the divots/rough spots in the concrete before epoxy (I think I will probably go with Epoxy-coat, they are based in the state) I could do multiple coats of epoxy, but I think that will be EXPENSIVE.
Could I float a coat of self leveling concrete compound over all of it then epoxy? Would this provide the compression strength for a lasting floor? Any other ideas?
In a perfect world I would float 2-3 layers of epoxy on the floor, first 1 or two to fill the indents, then a final. Can't justify the cost for this place though.
Here are pictures- The spalling/rough areas are probably 60%+ of the floor. Some spots are up to 1" deep, although most less than 2" diameter.
Any assistance appreciated...
