Todd.Brock
As part of the kitchen remodel, I am moving aN oven. I have a circuit running through the basement that fed the original range. It is 6 gauge copper wire, and a ground that looks to be about 10ga. It is breakered at 60 amps.
I intend to repurpose this circuit for a subpanel. It will power the new kitchen oven that only requires 30 amps. I will use the remaining capacity for a small woodshop in the bsmt
What is the best way to do attach a panel to a concrete foundation wall? Tapcons? Piece of plywood held on by tapcons, then screw board to it? Sleeve anchors?
My original intent was going to cut 2x4s the size of the panel, attach with tapcons and then screw panel to 2x4. But that was just my plan and is subject to correction!
