How to: Build an emission smoke leak detector
kunkernator
US of A
Alright guys, after reading another member's post regarding a guy on eBay making, and selling cheap emissions leak detectors for under $150, I decided to make one!
The idea is to create a simple, cheap smoke machine for UNDER $50. That way, all my fellow members can make one of their own (with their own improvements).
This is my first "how to" write up, so bear with me. If anyone points out anything I forgot, I will add it in. Feedback is great, and share your improvements too. I have had a lot of improvements in mind, but wanted to keep it basic for the "how to".
First, let me inform the less educated, what this tool is intended to do.....
An emissions leak detector is designed to fill your vehicles evaporative emissions system with a harmless smoke, which will then find its way out of the system thru any leak points. It can also be extremely useful in diagnosing exhaust system leaks, as the same principal applies.
Why can you not just use a normal "theater" smoke machine?
Well, these use a water based smoke fluid, which can be harmful to your evaporative system. An automotive smoke machine uses an oil based fluid (in this case, mineral oil), which may leave a residue, but is harmless.
Let's get started with a parts list. I have included prices, which are rounded to whole dollars, to give an idea of final price. ALL of these items can be found at Home Depot, Amazon, and Radio Shack.
1 Gallon Paint Can- $5
10 feet 3/8'' clear tubing or vacuum hose- $5
Battery clamps with wire leads- $10
2x brass drain bushings (3/4'' outside, 1/2'' inside)- $5/piece
Fuse holder/10A fuse- $5
Vacuum hose reducer (fits various sizes)- $3
3/8'' brass ******- $3
3/8'' brass elbow- $5
1/2'' to 3/8'' brass reducer- $4
1/2'' to 3/8'' brass ******- $3
1/2'' to 3/8'' plastic elbow ******- $2
1/4'' brass ball valve- $8
1/4'' male air hose fitting- $2
Alligator clips- $1
Various heat shrink- $1
Binding posts- $5
24g Nichrome wire- $6
1psi propane regulator- $10
Fiberglass wick- $1
4x 1/4'' flat washers- $1 (not shown)
2x 1/4'' rubber washers- $1 (not shown)
2x small spade terminals- $1 (not shown)
Now, some general tools you will need;
Soldering iron and solder
Step drill bit that reaches 7/8''
Wire strippers/crimpers
Drill
Drill bit set
Pipe sealant/teflon tape
2 adjustable wrenches
Sharpie
(the silicone is not used, rubber washers are used instead.)
And for the smoke fluid, I used UV dye and baby oil (100% mineral oil).
The UV dye will assist in finding leaks. Just make sure you use a type that will mix with oil (A/C dye).
Now lets start!
First to build, is the air inlet.
Gather up the following fittings and parts.
And now we will mock them up as such.
Now cement them together. Pay attention to how the regulator is clocked.
The air inlet assembly allows you to connect an air source, and then allows you to turn it on and off at demand.
Now, lets build the smoke outlet.
Gather the following parts.
And assemble them as such.
Your clear hose, will serve as the discharge hose and connect to the plastic elbow.
Next, lets make the inlet/outlet assembly.
Mark two spots on the lid of the paint can, roughly 1'' in on each side.
Drill a 1/4'' pilot hole in each spot, then continue with your step drill bit and enlarge the holes to 7/8''. Debur with the same bit on the inside and outside.
Attach your inlet and outlet to the lid as such, with the rubber washer on the outside.
Now take a small piece of your clear tubing, cut approx 4'' long.
And attach it to your assembly. This tube directs inlet air to the bottom of the can, thus pushing your smoke up and out.
Now, we will start with the electrical assembly. Put your lid aside.
Mark two spots on the paint can, roughly two inches from the bottom, and then one inch from each other.
Drill out two 1/4'' holes where you marked. Install the binding posts with a hard washer and rubber washer on the outside, and a hard washer on the inside (not shown).
Crimp an alligator clip on the inside of each binding post.
Gather your battery lead/wire, and your fuse holder. Trim and strip the wires as such.
Solder the fuse holder to your leads. REMEMBER to put your shrink wrap on first!
Shrink the heatshrink on the wires. I added a smaller large piece of heatshrink to hold the wires together.
Now, crimp on two spade terminals, and put your 10A fuse in the holder.
You can now connect the wires to the binding posts, and tighten them down.
To make the smoke element, you will need a short length of Nichrome wire, and a 3'' piece of fiberglass wick. Assemble as such.
Attach the wick inside to the alligator clips like so. Ensure the bottom of the wick is touching the bottom of the can.
Soak the wick in mineral oil (baby oil), and fill the can up approx. 1/2'' (add UV dye if you desire)
Seal the can lid on, then attach the remainder of your clear tubing to the outlet, and put the vacuum tube adapter on the end.
You are now done!
How do you use it?
Connect air to the inlet, and turn on. Then connect your battery leads to a 12v supply (car battery) within seconds, you will start to see smoke pushing out of the hose. You can use different adapters to adapt the machine to your specific needs.
How does it work?
The Nichrome wire acts as a heating element, and "burns" the mineral oil. It produces smoke.
SAFETY NOTE
The Nichrome wire DOES get very hot, red hot. Do not touch it while it is energized. If your wick goes dry, it will catch fire. Check your fluid level often to prevent this. I am not responsible if your hurt yourself or damage property.
K
kunkernator
US of A
Awesome tutorial! Thanks so much for taking the time to do this. What pressure is the air regulated to?
1psi. I will also add, most manufacturers call for less than 1.5psi when pressurizing the EVAP system, so as not to damage it.
signcrafter
Nice write up. Where did you get the regulator from?
In the other thread you were talking about I linked to a guy on youtube that was building these with a flow meter in them. One of these are on my to do list but that list is long.
K
kunkernator
US of A
The regulator was from Amazon. I cant link it on my phone. What i can say, is that i was forced to order it, all the regulators i found locally had a hose cripmed on. You want a "universal" regulator, with 3/8" NPT outlet and 1/4" NPT inlet fittings. If you havent figured out, these regulators are designed for use with propane gas, but it is the same principle, and gives you similar pressure when used with compressed air.
I did watch that video you are refering to. Great idea, and i may add it in the future. For now, i want to keep it simple.
Kellyblues
Indiana
Great build! Im sure it works great. i hate to be the barre of bad new but baby oil will hurt the sensors in most of today's vehicles. I did a series of tests a few years ago in the effort of debunking that baby oil would cause harm. I was wrong, it absolutely does. Don't know what it is, just know for sure it does. Usually the first thing to start jacking up are the check valves and then the vent orifices. Its not if, its when, I promise ya.
FYI I've been ASE master certified for over 20 years.
K
kunkernator
US of A
Thats interesting. I know the Snap On fluid we have used is made of pure mineral oil. The baby oil i purchased is unscented and is also only mineral oil.
If you dont feel comfortable using baby oil, or store bought mineral oil, you can always purchase a commercial smoke machine product (OTC, Snap On, etc).
Thanks for the info. I will leave it up to the user on what they will use, taking all information in to account.
The main idea of this thread is to build the machine, whatever you use inside of it.
Flat-rate
Our smoke machine uses nitrogen, less chance of fire. Filling a fuel tank with fresh air doesn't sound safe.
K
kunkernator
US of A
I ageee the nitrogen reduces the risk, but countless manufacturers use compressed air. Matco, Snap On, and OTC, to name a few. They all use compressed air, or internal air compressors.
I believe this was also discussed in a different thread.
If you choose to use nitrogen as your form of compression, you can adapt the inlet to work as such.
twistinglane
Maryland
I'm getting ready to work one up as well. Perhaps allowing for use with nitrogen. Any more experience with these builds in past month? Thanks for all the plans and ideas!
redmondjp
Redmond, WA
Very easy to do if you want to use nitrogen - you'll still need a regulator on your bottle, and if you use nitrogen exclusively and have a low-pressure regulator right on the bottle, you can omit the propane regulator on this unit.
K
kunkernator
US of A
No problem. Since posting this "How to" i did obtain some legitimate evap smoke fluid, it works just the same as baby oil, but will not cause harm as some have stated. As for the nitrogen, if you want to use it you can, if not, there is no problem with compressed air IMO. Most of the commercially available machines are able to run off shop air or nitrogen.
I have used my machine to find an exhaust leak on my truck (manifold turned out to be leaking on the #7 cylinder). And it worked excellent. The residue of any oil it left in the exhaust caused no issues to my knowledge, not even any smoke.
rodsnratfinks
California
This is great stuff. Thanks! I'm already thinking about what items I could substitute to improve mine. Perhaps using a small jerry can or something. You've done a great job of using inexpensive readily available parts, I'm just brainstorming how I can make a rugged self contained one moi similar to the commercially available units. In any case, this is a great idea. I could really use one of these, and they are so expensive.
Sent from my SM-G920V using Tapatalk
Jarhead0408
Who knows?
I'll be building one of these in the next week or so to find the leak on my wife's Expedition.
Thanks again for the right up.
cloves
I hate to revive this old thread, found the adapter used for the tip at autozone its a "Dorman Vacuum Connector and Tubing"
