How to clean iron pipe fitting threads on old plumbing work
tominboise
I have to replace a 3/4" valve in a cold water supply line. I am going to do most of it in PEX but the existing work is galvanized. What's the hot ticket to clean the internal pipe threads on the existing work? Some sort of wire brush? Use a ****** as a thread chaser? Don't worry about it? I will be assembling with tape and pipe sealer over the tape.
driftpin
Wire brush chucked in a drill will make quick work of it
Isn't he referring to a female fitting? The OP? Even a Dremel radial brush is probably too-big, maybe a cup-brush. I think I'd just use a decent male pipe piece, and cut 2 or 3 cut-off disc channels perpendicular to the threads, and use that to chase the female coupling's threads. Blow out or shop vac to remove any particles, best as you can.
mike93lx
Richmond, VA
Norcal
I have 1/2", 3/4", 1 1/2", 2", 2 1/2", pipe taps that work pretty decent for cleaning up threads, the 2 1/2" is not something that would use much but ended up with it, took me a while to realize what it was, but the 1 1/2" saved my bacon a couple of times.
T
tominboise
I bought a fitting brush last night and will use that. I also have a new pipe ****** that I can use to chase the junk out of the threads if needed.
Leaflessshadetree
Don't ask.
I'd use a wire brush. Years ago I started use wire brushes on new fittings and pipe. It really bumped my success rate on having 0 leaks especially with big box store fittings.
lolaetype
North Western Arkansas
I bought several different sizes of gun cleaning brass brushes that work well for cleaning female threads. Just chuck the threaded end of the brush into a drill.
DGersic
DeKalb, IL
I found some small wire wheels at Farm & Fleet that were just the right size for 1 1/2” pipe. Chucked in drill, ran it in and out to clean up the threads.
These were cheap, with the wheel just crimped to the arbor. They needed a tack to be solid, otherwise they started to spin on the arbor.
cannuck
Rural SK
The ONLY thing I have ever encountered with 2 1/2 NPT threads are the rapid pressure rise detecting devices on oil filled power transformers....so I also have the tap to fit (and clean up crud in threads). I think we should form the 2 1/2 pipe tap club - very exclusive.
Jim greengo
Behind my house
It's usually not a problem,if it's that bad replace the fitting.
Other wise id say slop some rector seal Tplus 2 on the new fitting and run it in.
rustyzman
Chicagoland
Yeah, even a Hertel USA HSS one is over $300 and that's not even for an interrupted thread one. This is why I love estate sales...
Still have not used it, but for nearly free I will keep it at the ready in case!
