rosana1884
- Joined
- Nov 27, 2012
- Messages
- 5
The clean tile is very bid problem. The following are the some tips for keep tiles clean.
Do clean up spills as quickly as possible so your grout won’t become stained.
Don’t use steel wool, scouring powders, or other abrasives that can scratch the finish of your ceramic tile.
Do remember that while ceramic tile is very durable, it’s not indestructible and may crack or chip under extreme force.
Don’t use bleach or ammonia-based cleaners — these products can discolor your grout if used too often.
Do take the proper precautions when moving heavy objects across a ceramic tile floor.
Do cover furniture and table legs with protectors to guard your floor against scratching.
Do remember that if a repair is necessary, the replacement product may be a slightly different dye lot and/or texture than the original tile, however, with time and usage, the replacement tile will blend in with its neighbors.
