How to create a arch in joists?
bkvanbek
I built a raft 12' wide and want to build an upper level using 2x8s. How do I create an arch to shed water? Ideas to cover it that would be suitable for foot traffic?
Skiff Builder
Southern NJ Coast
How long is the overhead to be?
Option A:
This is how I spanned 8'6" , arched deck and pilot house overhead on my last boat build. You could scale up the sizes for 12':
Sawed 1.5 x 1.5" curved beams out of 2x10 White Fir stock. 4" high crown over 8'6".
Glued/fastened 3/16" plywood on bottom of beams.
Cut sheets of 1.5" XPS foam to fit between beams. Glued to bottom plywood.
Covered top of beam with 3/8" ACX fir plywood, glued and fastened to beams and foam.
1 layer of 10 oz fiberglass cloth laminated with epoxy resin on top surface, than painted.
Strong, light, insulated, moderately complicated, but somewhat elegant.
Option B:
For a more of a get it done and get on the water :
Saw roof beams out of 2x10 ( lightest specie you can get -spruce/fir)
16"oc
Give it a crown of 4.5" or so.
1/2-5/8 ply on top, glued and screwed with PL Premium. Non skid paint.
Thin 3/16 ply on bottom of beams would really add strength.
Option C:
Standard deck construction. Just pitch entire overhead in direction of your choice.
You can use fiberglass window screen and laminate on top with Titebond 3 wood glue, sprinkle with beach sand for non skid-waterproof deck.
Bunch of ways to get this done.IMG_1532.jpegIMG_1616.jpegIMG_1632.jpegIMG_1637.jpegIMG_1641.jpegIMG_1764.jpeg
75gmck25
Alexandria, VA
Also be very aware of what that extra weight up high will do to the seaworthy ability of your raft. There was a boat that capsized a few years ago (in the Wisconsin Dells, I think) and they found it had been modified without going through the proper Coast Guard approval for a charter boat.
The original cover for the boat passengers was canvas on a metal frame, so quite light. When the boat was modified they used a wooden cover and supports, but they never considered how top-heavy it was. Once it got into really choppy water it rocked back and forth enough to simply tip over and dump out all the passengers.
