How to cut service line - tool question
Marc Voorhees
Apologies if this was discussed somewhere and my searches didn't find it:
I am installing a sub panel to my garage, and I am planning on running 2-2-2-4 stranded aluminum service line.
Simple question is, what tool do I need to cut this after I run it? Do I need the two handed cutters? Or will 10" cable cutters work for this?
Other questions since I have you all here is, what size drill bit/hole should I drill through the brick into my basement for this line? Is there a better tool than a masonry bit for this?
Thanks in advance!
reader2580
Minneapolis, MN
I have used a hacksaw to cut larger wire like this although it can be slow. They make cable cutters to make this a lot easier, but it isn’t worth it for one project.
RPH
Michigan Thumb
Aluminum stranded. If I’m stuck in Mexico on a job and looking for a tool for this job. Go lopper’s for tree branches. Decent ones will slice right through and are cheaper. Big plus, easier to find!
sparky 1971
Central Iowa
#2 isn't very big. I use these to cut and strip the smaller wire like that. A lot of guys use linemans pliers to cut and a knife to strip it. If you are going to run it through a wall, it needs to be in conduit, probably PVC and a minimum if 1-1/4". Use a bit that the conduit will fit through.
You better edit your post to add the ground wire or this thread is going to go off topic in a hurry.
I am installing a sub panel to my garage, and I am planning on running 2-2-2 stranded aluminum service line.
Thanks in advance!
Need to backup here. you need 4-wire feeder for a subpanel. hopefully you didnt buy the wire already.
Too late. :D
Marc Voorhees
Sorry Sorry. there is of course a ground. was distracted by the kid. Haven't bought the wire yet, doing so tomorrow. I have edited the post :)
