Yup, they're pretty sweet...kind of the same way you cut copper pipe.go down to the auto parts store and borrow their chain pipe cutter, It looks like a chain wrench but it has cutter heads on each link.
Recip is the best for cutting through the pipe itself.
.....you need to cut where you can rotate the cutter enuf to cut all the way around the pipe,...maybe cut as far as you can one way, then flip the cutter over to do the rest,..or finish it with a hacksaw blade...
...I once bought a pipe cutter just for the same predicament,..very reasonable and worked great, ...you need to cut where you can rotate the cutter enuf to cut all the way around the pipe,...maybe cut as far as you can one way, then flip the cutter over to do the rest,..or finish it with a hacksaw blade...
I'll take what's behind door number 3-
Cutting torch!
Saws all. Name says it.
I have to cut the front exhaust pipe on a car with blocked catalytic converter. The bolts are rusted so I have to cut it out. What do you recommend: a 9 inch angle grinder or a recip saw? Thanks.
Keep in mind that a sawsall blade can be ground into for a custom length for special uses.
Don't cut the front, cut the back and clean the cat out
Use the chain cutter if you can borrow one. Sawsall if ya can't!
