How To Date Starrett Protractor Head
leg17
Kentucky
Look carefully along the bottom edge on both sides.
Early ones had the patent date marked (1879 or 1880).
The "checked" on the fill part looks pretty early.
As leg17 implied, 17 years after a patent date is the high end for how old it can be. Used to be that was as long as it was protected. Could obviously have been made the year patented, or 17 years later, using only that guideline.
AreBeeBee
Wisconsin
Does anyone have date info for the "checkered" pattern on Starrett squares (combo & double)? That pattern seems to have begun in the late 19th century and continued through WW2 until some date, when the company switched to the crackle and smooth finishes, respectively, for the cast iron and hardened steel heads.
