How to Dissolve Plastic
calandrod
Kansas
I’m looking for some great ways to chemically remove this plastic off my toolchest.
The previous owner had it too close to a fire and a tarp melted all over it. I’ve already power washed it and scraped all the loose stuff off. I’ll be sandblasting it after I get this off. Any good chemical ways to eat this stuff up or get it off somehow?
(Grasshopper for size reference)
flyingblind
Washington
Acetone first then Lacquer thinner diluted with acetone sparingly will dissolve plastic stickers and glue and paint. I would use a cotton swab to do it in small areas.
I just caught you are stripping it. You can use aircraft stripper.
Or just sandblast it and be done..
kerrynzl
Tauranga, New Zealand
M.E.K [Methyl ethyl ketone] or Toluene
M.E.K will take the paint off.
Toluene is better if it is heated.
Use Ventilation and don't stand down wind.
PCustoms
VT
If you're sandblasting it anyways.....
Just do that. Maybe use a razor scraper or sand the plastic off in the thicker spots.
4xdog
Santa Fe, NM
A plastic tarp is usually made of a polyolefin (woven slit-film polypropylene or extrusion blow-molded polyethylene). Those are not easily dissolved plastics.
I'd start working on mechanical approaches.
kerrynzl
@calandrod
They are usually made from "PE" [polyethylene]
I've used a solution of PE fibers dissolved in Toluene or Xylene to "solvent weld" with a hot air gun.
