How To Divide Tall Tool Chest Drawer In Half?
jonshonda
Wisconsin
I'm running out of room in my recently acquired Snap On Classic 78. I don't have the funds to upgrade to a larger box nor add a side box right now, so I am looking for alternatives. The bottom drawer in the Classic 78 is very tall, and I really don't have a use for that much depth.
Has anyone made anything to add another shelf or similar storage solution so I could put items like hammers, wrenches on the bottom and have a sliding shelf or similar on top to put more tools on? Basically you would open the drawer, and then there would be a half shelf on the top that slide back and forth so you could access the tools underneath.
1982fxr
Phoenix
I've had a couple old boxes that came factory with that. I think they were snap on. It just glides on the side rails, if I remember correctly.
MShaw
York, Pa.
I did this in a machinist's box that I use for my clock repair tools. If it was done for automotive tools metal construction would probably be more appropriate. The runners / risers that support the trays just lay there and lift out to remove.
PFSard
Mesa, AZ
I have a 1974 Snap-On KRA-377D bottom box with a sliding tray, which does slide on the drawer edges.
OP : Have you tried calling Snap On to see if there is anything that fits your model?
lilredex
Toronto
Something like this might work.
Larryjones
WV
Line edges of drawer with quarter inch ply, make a tray that fits on top of ply, smaller than drawer and slide it back and forth or just lift it out.
J
jonshonda
Wisconsin
^^Both great ideas. Hoping for something a little deeper then the orange tray above but it's the same concept.
Guessing it will need glides based on the weight.
Ohmthis
Outside of Louisville KY
This was my idea too. Pick a depth you’d like and cut plywood that depth. Screw short pieces across the drawer to tie them and give it some strength. Build a box out of plywood and set it on you runners. I’d make a handle to where you could lift the whole tray out when you need to. Also, think about ways to organize, maybe set up a smaller box on top, I built a side box out of a short file cabinet. I took 16 gauge and bent a lip, riveted it on, and hung it off the side of my work box years ago. They are plentiful, cheap, and It added quite a bit of storage.
Lynden
Southern California
Why make a sliding tray? Make it the same size as the drawer to optimize its usefulness. Lift it out to access the bottom of the drawer.
Ohmthis
I can see a reason to keep a section deep. If he was to put hammers, short pry bars, extensions in up and down, they would easy to get to vs lifting it out every time. Also a drawer full of tools may be pretty heavy to lift in and out every time you wanted something in the bottom.
rick carpenter
Huntsville, East Texas
Why not mount ball bearing slides inside the drawer and build/fab a shelf to fit? An alternative if in the top drawer you want say foam cut outs to securely hold tools, think about a shallow box with lid (like a cash box) on pin pivots at the back. That comes close to the lifting you don't want but it might work for you.
