I don't use the new washers with the new calipers,they don't seal and leak getting thrown in the garbage can.I reuse the old washers and no leaks.
I have heard guys say to use the old washers, not the new ones.
I usually use the new ones, don't think I ever had a problem.
But I bet I am tightening more that ~13ft lb of torque.
Thanks,
Tony
Torque wrench and flare nut crowfoot wrench.
Truth be told, you can do it by feel. If you're capable of replacing calipers correctly you should be ok tightening brake lines.![]()
Does the brake line have a banjo or threaded fitting on the caliper end?
Threaded on the left, banjo on the right.
I do it by feel too and there is another thing I do.I don't use the new washers with the new calipers,they don't seal and leak getting thrown in the garbage can.I reuse the old washers and no leaks.
Ok, Im a shadetree that needs to be schooled on this....
Does 13 ft lbs seems awfully loose to make sure a copper washer is sealing.
I was about to ask if that was an E46, then i saw the little writing at the bottom of the pic..![]()
u sir, have good eyes!
